Making my 50cc accelerate faster
iainsalter
PostPosted: 21:48 - 19 Mar 2008    Post subject: Making my 50cc accelerate faster Reply with quote
i just bought a yamaha BW SP-Y 50cc scooter. it has some sort of sports exhaust fitted which makes the bike go alot faster. im interested in making it accelerate faster for fun. could anyone tell me what i should buy which i could get fitted by a garage?[color=black][/color][size=18][/size] :D :D
nrg-mental
PostPosted: 22:09 - 19 Mar 2008    Post subject: Reply with quote
this realy depends on how much money you are wanting to spend, i would recomend a polini variator which are around £50. if you are looking to spend less then just get race rollers about £11 and cluch springs about £7...
21 and still on a bloody scooter : (
rezzin
PostPosted: 22:25 - 19 Mar 2008    Post subject: Reply with quote
All that was said above wont make the bike much quicker off the mark. Laughing If you want best 'bang for the buck' then wack a basic 70kit on such as the polini iron for around £70. The kit is good and provides most 'bottom' end punch so wheelie addicts love them,so i imagine there good off the mark. You have to spend to get gains im afraid.. Thumbs Up
nrg-mental
PostPosted: 22:27 - 19 Mar 2008    Post subject: Reply with quote
dont put a 70 kit on it unless you wanna blow your bottom end...
Teaman
PostPosted: 22:43 - 19 Mar 2008    Post subject: Reply with quote
if you just want it to accelerate faster put different rollers in the variator,
You will probably need to have a shop do this for you as you need a windy gun to remove the lock nut.
If you are thinking about a new exhaust its not that simple, some require you to de restrict your bit but some if there nice will give you all the things you need, rollers, and jet.
As you have an exhaust kit already fitted you could try the first option, rollers.
there fairly cheep at around £16
on a different note I believe the fastest accelerating 50 at the moment is the ludix blaster, Doesn't mean its the fastest, just gets up to 30 the fastest, or so I've been told
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
PostPosted: 23:50 - 19 Mar 2008    Post subject: Reply with quote
You can use a tool called a boa constrictor to hold the variator while you undo the nut. This is how I de-restricted my scooter.
Got the tip off a video of a guy de-restricting his Yamaha scooter on YouTube.
That is true. Liquid cooled 49cc putting out 6.2bhp when the exhaust is de-restricted. I was contemplating buying one if I got an apprencticeship at Honda last year. I never got the apprenticeship.
Joeb46
PostPosted: 10:44 - 20 Mar 2008    Post subject: Reply with quote
red powerbands are the best for acceleration and wheelies
go down to your local bike shop and ask them for one. usualy about £5 Wink
Current- Drz400sm- For sale
Kawasaki er-5 race bike# 106
rezzin
PostPosted: 11:40 - 20 Mar 2008    Post subject: Reply with quote
For goodness sake..enough with the powerband blags. Just because you put 'powerband' in a post it doesnt enter you into a special group or anything Rolling Eyes ..so i guess you can stop now? Thanks. Thumbs Up
tutton
PostPosted: 18:09 - 20 Mar 2008    Post subject: Reply with quote
I fort black was fastest as its knightrider speed? Laughing Laughing
Anyways
Exhaust.
Jets.
Rollers
Higher octane fuel
Iridium plugs.
Although some of those could damge your bike
PostPosted: 18:13 - 20 Mar 2008    Post subject: Reply with quote
tutton wrote:
Higher octane fuel
Iridium plugs.
Bother are going to do sod all to a 50cc.
tutton
PostPosted: 18:15 - 20 Mar 2008    Post subject: Reply with quote
Wrong,
Next time you get some time
insted of putting in 95 octane fuel in sainsburys
go to shell and put in some Vpower which is like 101 octane.
My bike goes like stink, and accelerates soo much better.
And the plug issue, im pretty sure better plugs do make a good difference.
PostPosted: 18:23 - 20 Mar 2008    Post subject: Reply with quote
tutton wrote:
Wrong,
High octane fuel ignites later. It really isn't flying when you put 101 octane fuel in. Probably just your imagination.
Iridium plugs don't do anything for 2 strokes. They are designed for 4 strokes.
PostPosted: 19:19 - 20 Mar 2008    Post subject: Reply with quote
tutton wrote:
Wrong,
I don't think V power is 101 octane. I'd say it was 98. Tescos do 99 octane which I think is the highest octane rating on the market atm.
It might be better in your bike because its full of detergents which probably help to clean all the crap out of your carb and possibly off of the piston and exhaust too.
Octane rating doesn't make anything faster unless a) its had an increase in compression ( enough to make a difference anyway, in which case lower octane fuel wouldn't work at all) or, b) it has a knock sensor and can run advanced ignition timing or more boost from a turbo.
High octane fuel won't make a 50cc go faster. Except by maybe Placebo effect.
tutton
PostPosted: 21:00 - 20 Mar 2008    Post subject: Reply with quote
O right,
felt faster and more responsive to me,
deffo works for turbo cars as thats what all speed trials do along with their hks drag fuel
and for reference
V-Power has a rating of 99 RON,
From wiki
cheers
Joeb46
PostPosted: 12:52 - 21 Mar 2008    Post subject: Reply with quote
shell v power makes a hell of a difference to my bike.
so much crisper and more responsive.
but i dont think it makes it any faster.
spose it would help if my speedo was working Neutral
PostPosted: 12:54 - 21 Mar 2008    Post subject: Reply with quote
As i've said before it won't make any difference. It's all in your imagination because the adverts say it's better.
It is only better in high compression engines as the fuel egnites under a higher compression.
If 95 RON is used in high compression engines detonation can occur.
Using any higher than 95 RON in a 50cc will probably make the bike slower as it is harder to ignite.
Finglonga
PostPosted: 16:20 - 21 Mar 2008    Post subject: Reply with quote
Sorry but you are wrong! It makes a big difference to your wallet. Wink
As to speeding up a moped, a tailwind will make more of a difference that Iridium plugs and high octane fuel.
Andy Sez....
F.Y.Y.F.F.
ZRX61
Victor Meldrew
PostPosted: 16:23 - 21 Mar 2008    Post subject: Reply with quote
KEErist there's some utter bollocks about octane posted in here.
Using a higher octane fuel without any other modifications to take advantage of the higher octane does 2 things
Makes the engine harder to start owing to the fuel being less volatile
Makes the engine run a bit smoother owing to the fuel being less volatile
& a 3rd thing if you run leaded Avgas etc:
Makes it smell nice & turns the inside of the exhaust white.
Joeb46
PostPosted: 19:03 - 21 Mar 2008    Post subject: Reply with quote
trust me it makes a difference, either that or the the other fuel i buy is shite Wink
PostPosted: 20:28 - 21 Mar 2008    Post subject: Reply with quote
It's just a pseudo effect. Because you are told it makes your bike faster you think when you use it your bike is going faster and running smoother. It's psychological.
I'm willing though for the benefit of everyone to fill my next tank up with it and tell you any differences I feel.
Should be interesting to see if I get the pseudo effect of the bike being faster as I don't actually think it will make my bike faster. It'll either be the same or slower.
binge
Emo Kiddy
PostPosted: 19:40 - 29 Mar 2008    Post subject: Reply with quote
Placebo. Wink
There is a gap of 1 year, 305 days between these two posts...
buchan69
PostPosted: 00:09 - 29 Jan 2010    Post subject: Reply with quote
i got a yamaha jog rr 50cc, its LC and only ways 79 kg dry weight, it went 43 mph when restricted.
i would say buy a carbon fiber reed box, go for some 3.5g rollers or maybe 3g if u want really fast aceleracion but not so good top end.
also buy 3 new clutch spings and a new tork spring.
a cavalier race belt, might be more but will last longer so all good.
um a 5mm fuel pipe, also u could get a bigger jet i incrusted mine by 20 sizes for the exhausted alone.
as u have a yamaha i would only recommend molosi part to you, get a molosi variator (hard to find but well worth the trouble) could go for a half or a quarter throttle if u really wana fly like a mad man, um could always go down the rought of making it lighter but thats allot of money.
yamaha jog rr 50cc
lonie This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 11:07 - 29 Jan 2010    Post subject: Reply with quote
Thanks for digging up this two year old thread.
The last post was made 16 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 129.13 Kb
