| ttr |
 ttr Crazy Courier
 Posted: 01:24 - 22 Mar 2008 Post subject: Just bled my brakes.... Slight woes? |
Righto
Basically overhauled my front calliper - new seals, good clean out, new pads, braided lines and bled the system today... Bar's tied back overnight as we speak.
Appears to all be working but for one slight issue..
Now I'm not 100% as in the time I've owned this bike the front calliper has either been knackered or sat on my work bench, but...
When wheeling it without the front brake applied, there's a bit, and I mean a bit, it's not VERY noticable, of friction, compared to how it was without the calliper attached.
So presumably this isn't right, so my question is, where have I gone wrong now?  ____________________ GS125-> NT400->VFR400->CRM250->Z750 + GS125->NTV650 rat + VMX1200->GSF600 + GPz550 |
 ---- World Chat Champion
| Thom |
 Thom World Chat Champion
| iooi |
 iooi Super Spammer
 Posted: 10:44 - 22 Mar 2008 Post subject: |
I've just done mine and they are the same. After a 30 min ride all is well. Yest they do still sound like they are just tickling the disk, but thats normal. Its when after applying them and you cant move the wheel you have problems. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| LeeR |
 LeeR World Chat Champion
 Posted: 17:38 - 22 Mar 2008 Post subject: |
My brakes drag slightly especially by Friday after 400+ miles of commuting, it's all the crud they pick up. However, even after a rinse down and squirt of brake cleaner there's still a bit, as you say just a bit, of friction there.  ____________________ My claim to fame: Austin Vince nicked my pen... |
| ttr |
 ttr Crazy Courier
| virus |
 virus World Chat Champion
 Posted: 10:06 - 23 Mar 2008 Post subject: |
lift the front end up, if you can spin the wheel without it stoping dead within a quarter turn of you letting go, then its ok.
Cheers
John ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| ttr |
 ttr Crazy Courier
 Posted: 20:21 - 23 Mar 2008 Post subject: |
spins about 90-100 degrees, tops. With quite a bit of effort  ____________________ GS125-> NT400->VFR400->CRM250->Z750 + GS125->NTV650 rat + VMX1200->GSF600 + GPz550 |
| virus |
 Posted: 20:30 - 23 Mar 2008 Post subject: |
id take the pads out, lever the caliper back and bleed it a little bit more, sounds like its got a small ammount of air in it causing a problem.
Cheers
| Jockey |
 Jockey Scooby Slapper
| loply |
 loply World Chat Champion
 Posted: 21:39 - 23 Mar 2008 Post subject: |
Did you lube the seals up with brake fluid?
Most bikes i've seen your wife would be able to spin the wheel the best part of 360 degrees on her first attempt.
Check also the pad is seated right. Some calipers have grooves or kinks for locating the pad, which if positioned incorrectly can push the pad outwards. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| bugsy46 |
 bugsy46 Village Idiot
The last post was made 17 years, 309 days ago. Instead of replying here, would creating a new thread be more useful? |
