Best way to fit a ground anchor in a shed?
Nb
PostPosted: 09:31 - 22 Mar 2008    Post subject: Best way to fit a ground anchor in a shed? Reply with quote
What with all the bikes where i live going missing im needing some extra security in my shed. My shed sits on slabs in my garden with are properly laid. But has anyone put an anchor in through their shed floor? And is it pointless putting an anchor into slabs?
And can anyone recommend a good anchor that may be suitable?
Ichy
PostPosted: 10:29 - 22 Mar 2008    Post subject: Reply with quote
If you going to fix it through a slab try to make sure that you are closer to the middle than the edge and that the fixings are long enough.
Much better if its one of the concrete council type slabs rather than the wickes type. The older ones can be a pita to break while the cheaper type fall to bits if you drop them.
Nb
PostPosted: 11:05 - 22 Mar 2008    Post subject: Reply with quote
The slabs are the council type, fooking huge. Laughing So im guessing you just drill the holes and then put resin, or concrete in. Thinking
Ichy
PostPosted: 12:15 - 22 Mar 2008    Post subject: Reply with quote
Different locks have different types of fixings. Some need to be concreted into the floor while others bolt down.
The bolt down ones use metal rawlplug type fixing and these do sometimes use resin to hold them in.
I can't recommend any since I made my own but I'm sure if you ask in the general bike section you'll get a fair few opinions to work on Wink
Nb
PostPosted: 17:05 - 22 Mar 2008    Post subject: Reply with quote
Got a cheap oxford one for now, my chain is shite anyway so it will need upgrading next time. Seems to be well stuck in there Laughing
https://img.photobucket.com/albums/v678/blazebrown/ghettoanchor.jpg
Ted
PostPosted: 17:17 - 22 Mar 2008    Post subject: Reply with quote
Tisk... you coulda made a neater job of the floor!
Very Happy
Nb
PostPosted: 17:23 - 22 Mar 2008    Post subject: Reply with quote
Couldnt be arsed. Laughing Just drilled loads of holes round the anchor then punched a flat blade screwdriver through. Embarassed Laughing
The last post was made 17 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 51.94 Kb
