Suspension/Height Raising
NSRboi
PostPosted: 12:33 - 19 Jun 2002    Post subject: Suspension/Height Raising Reply with quote
Have a 2001 NSR125R. Does anyone know, is it possible to raise the suspension/height a bit (say about 1 inch?)
Never underestimate the healing powers of custard.
Get in touch with yourself by touching yourself. If anyone is watching, stop touching yourself.
RFT
PostPosted: 14:41 - 19 Jun 2002    Post subject: Reply with quote
It's possible, but you need a specfic tool- if you look at the shock you can see an adjusable ring at the top of it... Front end's non-adjustable though (apart from physically lowering the yoke on the forks...)
Korn
Admin
PostPosted: 14:58 - 19 Jun 2002    Post subject: Reply with quote
You can't raise the front as such, but you can stiffen it up by using heavier weight fork oil and overfilling it slightly. We did this to Kris' to overcome the fact that he totally dwarfs the thing Wink
Kris
PostPosted: 15:02 - 19 Jun 2002    Post subject: Reply with quote
Whats with this 'we' thing?
I did it all myself, honest. Laughing Laughing Surprised Laughing Laughing
PostPosted: 22:23 - 19 Jun 2002    Post subject: Reply with quote
Kornel wrote:
You can't raise the front as such, but you can stiffen it up by using heavier weight fork oil and overfilling it slightly. We did this to Kris' to overcome the fact that he totally dwarfs the thing :wink:
Also you can preload the springs a bit by putting a suitable coin (or more) on top of the spring then putting the top back on the fork
RFT
PostPosted: 08:06 - 20 Jun 2002    Post subject: Reply with quote
Sneaky- I like it...
Dylan
PostPosted: 18:27 - 20 Jun 2002    Post subject: Reply with quote
How hard is it to refil the oil, you dont have to take the seals out do you?? And do they drain easily, or do you leave them hanging up for days with a constant drip coming out Laughing ??? I feel mine bottoming out, they havnt had new fork oil in the 12yrs of its life, most probably shot then!!
Thanks
Dylan
Korn
Admin
PostPosted: 19:34 - 20 Jun 2002    Post subject: Reply with quote
Get a syringe with a length of rubber hose, take the fork nuts off and siphon it out... Refill and replace the fork tops - voila!
Scooby
Scrappy Doo
PostPosted: 19:45 - 20 Jun 2002    Post subject: Reply with quote
Hmmmm syringe......he one time being a junkie would help you in life!!
Dylan
PostPosted: 07:03 - 21 Jun 2002    Post subject: Reply with quote
Thanks, sounds quite easy, but i do have a knack of cokind things up!!! Ime 10stone, what weight oil do people recomend???? I want them to be a bit stiffer, ive got into a few nasty slides when they bottomed out, and i think this caused the front wheel to skid.
Dyl
PostPosted: 22:36 - 21 Jun 2002    Post subject: Reply with quote
Fitting thicker oil does not make the forks stiffer really, and wont stop them bottoming out. The springs make them stiffer. The air gap above the oil acts as a kind of spring, so using slightly more oil will make the forks stiffer, and using slightly less oil will make them softer
Dylan
PostPosted: 12:45 - 22 Jun 2002    Post subject: Reply with quote
Thanks
Will try it sometime.
Dyl
TJ NSR
PostPosted: 16:05 - 23 Jun 2002    Post subject: Reply with quote
just stiffened the rear suspension (preload) and its great the bike now handles much better and feels like it wants tobe on the track, all i need now is stiffer springs for the front forks!!!
The last post was made 23 years, 183 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 73.82 Kb
