Number plate lights and the MOT
Polo
PostPosted: 12:23 - 04 Apr 2008    Post subject: Number plate lights and the MOT Reply with quote
I cannot seem to find a suitably reputable source that says you MUST have a number plate light or whether, if one is fitted, it MUST work.
My bike does not have one and wonder if I need to install one and if so - how did it pass the last MOT?
Thanks for any help.
My mum smells your fingers
PostPosted: 12:44 - 04 Apr 2008    Post subject: Reply with quote
Here you go. Not the MOT requirements, but the requirements for them to be fitted:-
https://www.opsi.gov.uk/si/si1989/Uksi_19891796_en_4.htm#(Tiii)24requirementaboutusefrontrearpositionlamprearregistrationplatelampsidemarkerlampendoutlinemarkerlamp
Suggests you can get away without them during the day.
https://www.opsi.gov.uk/si/si1989/Uksi_19891796_en_20.htm#nsch15requirementrelatingobligatoryrearregistrationplatelamp
Says they are required for any vehicle first used after 1st April 1986 (and also the numberplate light must have an approval marking).
https://www.opsi.gov.uk/si/si1989/Uksi_19891796_en_6.htm#nschiobligatorylampreflectorrearmarkingdevice
Says they must be fitted (table 2 for bikes) with the only exemption being vehicles which do not need a registration plate.
So, although you might find a tester to pass it you can still be done for riding it without any approved numberplate illumination. Only exemption might be the fiddles to do with an MOT for a vehicle only used in daylight, which would require most of the other lights to be removed.
mr.z
PostPosted: 12:49 - 04 Apr 2008    Post subject: Reply with quote
https://www.motuk.co.uk/mcmanual_110.htm
Oddly i can't see anything mentioning the plate lights apart from the link. Might be on there somewhere.
Why not just phone the place your taking it to and ask them?
As far as I'm aware you do need one, whether they'd notice or check is another thing (since plate lights are usually shite and in a reasonably well lit workshop you'd probably not see them)
edit: Also, what will pass an mot doesn't necessarily relate to what is actually legal. Were you stopped by some arsey traffic copper it gives him a perfect reason to fine you.
Ariel Badger
PostPosted: 12:57 - 04 Apr 2008    Post subject: Reply with quote
If you have lights on the bike you need one but if the intended use is daylight only you do not but you will still need a brake light.
Ariel Badger
PostPosted: 12:59 - 04 Apr 2008    Post subject: Reply with quote
I had a Land Rover fail an Mot on number plate light not being fitted.
PostPosted: 13:11 - 04 Apr 2008    Post subject: Reply with quote
Strangely you can read the MOT regulations such that a brake light is not required. The test rules apply to vehicles fitted with a stop lamp, and then it lists a couple of types of vehicle that do not require a stop lamp. Doesn't say that any not in that list must have a stop lamp, just the same as it says for headlights and which people read as there being no requirement for a headlight.
I woudl say the MOT rules can be read to say that anything registered after 1st January 1931 must have a headlight.
Polo
PostPosted: 20:25 - 04 Apr 2008    Post subject: Reply with quote
Thanks for the info. I will look to get one installed sooner rather than later.
The last post was made 18 years, 132 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 56.12 Kb
