Blindspots.
st3v3
PostPosted: 15:11 - 06 Apr 2008    Post subject: Blindspots. Reply with quote
Ok, I'm pretty damn bored couldn't see another thread although it was mentioned, and may help new members/riders at some point.
Cars, vans, buses and even bikes have blind spots. Best thing to do not to get involved with them is to be aware of the places you won't be seen and stay away, unless you have an abnormal tendency to like pain, a quick fright/thrill and hospital food.(along with a mashed bike) Mr. Green Best way to be noticed, if even for a mere split second is make eye contact with the driver where possible(hardly, then), most people only glance at things for a 1/10 of a second and then forget anything not important to them, including you.
Make an example with buses, being quite big, long things and not to be argued with, drivers generally believe they own the road but being small and singular we can't really argue. Sad Blinds spots are generally just to the rear of the doors at the front people use to get on, about a bike's width away from the bus(as with most things).
https://www-nrd.nhtsa.dot.gov/departments/nrd-12/3839/pages/Ch11-Tutorial-2_clip_image002_0000.gif
Of course, the rear can often be blocked just by moving passengers, not that many bikes can see or are tall enough to be seen through it anyway.
Similar vehicles will have similar points, so no need to type 'em all out.
Rest are similar but you'd be surprised how far back the area goes, and I think the following pics nabbed off Google will show pretty much everything in general.
People are welcome to add stuff(even constructive criticism) or the thread will die and be done with. Laughing
Truck:*ahem, posted as LHS due to foreign trucks driving around here* Wink
https://www.worcadvmot10.fsnet.co.uk/54_blindspot.jpg
Lorry:
https://www.motorcyclebasics.com/blind22.gif
Average family saloon(drawn as a Volvo, nice.):
https://blog.wired.com/cars/images/2007/11/07/3568_2_1.jpg
Another, both sides:
https://germancarscene.com/wp-content/uploads/merc-28-09-07.jpg
Little different:
https://pages.cs.wisc.edu/~gdguo/driving/blindspot_files/image001.gif
Bike(should know this, really):
https://tbn0.google.com/images?q=tbn:UsJ0GjgAmxCEyM:https://www.industryresearch.com.au/motorcycle/Swann%2520Insurance%2520Motorcycle%2520of%2520the%2520Future/15%2520Swann%2520Dynamic%2520Control%2520blindspot%2520warning.jpg
Trucks also need to swing out to the opposite direction they are turning to be able to swing in, only thing you'll achieve by getting on their 'inside' is being squashed, unless they see you but this is unlikely and it's not surprising, you should have contemplated this before making the move. If you do this, hit the brakes, try going backwards before the inevitable crunch.
If you don't get in a position to be whacked, simply have a lil patience and after a few seconds it will be round where it wants and out of your way. Don't go he long way round it prematurely as some numpty may come the other way and won't know your there....
American pic again, (but you get the jist):
https://mobikefed.org/files/truck-blind-spot-bw.png
kitty kat
PostPosted: 17:22 - 06 Apr 2008    Post subject: Reply with quote
I always follow the rule, if you cant see the mirrors of the vehicle in front, then you cant be seen.
To make myself more visible I also move about in the lane, so if you end up in a blind spot you are not in it for long.
KTM Gordo
PostPosted: 17:50 - 06 Apr 2008    Post subject: Reply with quote
I notice that it's a left-hand drive bus - reverse the picture for the UK.
Something that I discovered last weekend when I test-drove a car is that the A pillars (the front ones) are getting thicker. In the SEAT Althea, I felt I was always looking around it to see what was going on. This is a knock-on effect from the Euro-NCAP tests, because a stronger A pillar makes a big difference - but a stronger pillar is a thicker one, and the blind-spot behind it is bigger too.
Also, this trend for tinted back windows makes it harder to see when you look over your shoulder before changing lane. Not that most non-biker drivers would know what a life-saver is - I always do them in the car: old habits and all that...!
Change is inevitable - except from a vending machine.
KTM 990 Adventure | KTM EXC 250 Racing | Land Rover Freelander SE Td4
KTM Gordo
PostPosted: 18:08 - 06 Apr 2008    Post subject: Reply with quote
Confused Question
iooi
PostPosted: 18:11 - 06 Apr 2008    Post subject: Reply with quote
Even in a car the MSM routine should always include a glance over the shoulder to clear the blind spot. At least that is what you were taught years ago.
I go with KK and the if you can't see the mirrors then they sure as hell can't see you, and take it one step further if you can't see their eye's and don't expect to make eye contact. That is never happening, all they are doing is seeing you.
Always remember any large vehicle when turning will always move out to the opposite side before turning. So if they are turning right, be prepared for them to move to the left first before swinging right.
Never place your self between them and a roundabout, many arctics can't swing round in the single lanes.... Seen many a car do this and end up standing on the brakes as they get squesed....
Even better advice is never put yourself in a position were you do not have a escape route.
Itchy
PostPosted: 18:12 - 06 Apr 2008    Post subject: Reply with quote
No no no no NO,
This picture reflects reality a bit better,
The blue bit is the blind spot,
The top picture is normal driving,
The bottom picture is a typical manchester commute run, and it is the default bikers survival assumption that nobody is looking.
https://farm3.static.flickr.com/2346/2392411041_77b1a93c26_o.jpg
Kay-J
PostPosted: 18:15 - 06 Apr 2008    Post subject: Reply with quote
I always make the assumption that they can't see me unless they make clear acknowledgement of my presence on the road, which is usually some wanker trying to overtake me.
like a true natures child....
kitty kat
PostPosted: 18:16 - 06 Apr 2008    Post subject: Reply with quote
pmsl @ Itchy
sad to say it is true though Sad
st3v3
PostPosted: 18:38 - 06 Apr 2008    Post subject: Reply with quote
Only picture I could find mate, iooi, will edit it about the whole wagon turning, nearly put a pic up about that but didn't bother, should have. Laughing
PostPosted: 18:48 - 06 Apr 2008    Post subject: Reply with quote
It's good reasoning to follow, but you should also understand that if all you can see in the vehicle's mirror is the passenger's seat, you're probably in or almost in the near-side blind spot. Moving out wider is a very good point because if you are out wide AND still in the blind spot you're probably far enough back that you're not longer alongside the vehicle. Moving across the lane also makes you more likely to be noticed by a driver, as you are moving across their (reflected) field of vision.
KTM Gordo
PostPosted: 19:03 - 06 Apr 2008    Post subject: Reply with quote
Something else to bear in mind is that there are a lot of left-hand drive trucks coming over to the UK these days - and their blind spots are the reverse (actually, the same as the ones Steve originally posted).
There was a programme on ITV1 last week about the accidents they have because of the poor visibility to the off-side.
What this means is that if you've got a vehicle on non-UK or IRL plates then take extra care - give them plenty of room, and don't loiter alongside them.
Good thread this Thumbs Up
PostPosted: 19:46 - 06 Apr 2008    Post subject: Reply with quote
I've actually seen one such accident. I was driving on the inside lane behind a foreign articulated lorry on the M25 and a small car was in the middle lane very slowly overhauling the lorry. The car got right up to the front wheel when suddenly the lorry pulled into the middle lane, clipping the car which went spinning off the motorway hitting the hard-shoulder barrier. It was quite a mess but the driver wasn't hurt. The lorry driver had no idea the car was there. Initially the driver didn't even realise he had even hit the car, until I and another driver made him pull over and stop.
st3v3
PostPosted: 21:13 - 06 Apr 2008    Post subject: Reply with quote
Sounds nasty, were they ok?
Need more think Bike Ads but with info like this methinks.....
bigjim
PostPosted: 09:22 - 07 Apr 2008    Post subject: Reply with quote
You run the Mancunian Way gauntlet too Wink
Itchy wrote:
No no no no NO,
'97 - Thundercat - Sold
'08 - R6 - The Pocket Rocket - Sold
'09 - Street Triple R - The Monster
McGee
O RLY?
PostPosted: 09:51 - 07 Apr 2008    Post subject: Reply with quote
Dress like this:
https://img255.imageshack.us/img255/5015/stevenb4.jpg
Problem solved.
Its pronounced Jixxer!
deanoet
PostPosted: 16:08 - 07 Apr 2008    Post subject: Reply with quote
Apart from in slow moving traffic there is no reason to be next to somebody for any length of time, and you "should" be aware of what is around you for an escape route if the car / van / bike / tosser does move into your lane.
I always hover my thumb on the horn when overtaking anyone on the motorway / dual carraigeway
If you cant see the drivers eyes they have no chance of seeing you, so dont ride / drive there Smile
st3v3
PostPosted: 19:13 - 07 Apr 2008    Post subject: Reply with quote
Doesn't matter how good a rider you are, you can never compensate for the other muppet on the road that doesn't see you. Less chance of that if you know where not to be.
PostPosted: 20:21 - 07 Apr 2008    Post subject: Reply with quote
It's brightening-up now so is much less applicable but since I ride through the winter (and drive my van too) I have noticed that riding with your headlights on around dusk WILL allow a driver to know you're in the blind-spot as he will see your headlight shining on the road in front of you.
deanoet
PostPosted: 20:26 - 07 Apr 2008    Post subject: Reply with quote
On a bike always ride with them on TBH
All new bikes u cant turn them off, just pick between dipped and full beam. Smile
Also a good tip is that in low sunlight if it is behind you, the oncoming cars are looking straight at it so will have a much reduced view, especially if the road is wet
st3v3
PostPosted: 20:38 - 08 Apr 2008    Post subject: Reply with quote
Maybe in that case I'd rather have my light off.
Surely more chance of seeing a red bike coming at you than another light, when you already have the sun near glaring you out.
PostPosted: 20:53 - 08 Apr 2008    Post subject: Reply with quote
KTM Gordo wrote:
What this means is that if you've got a vehicle on non-UK or IRL plates then take extra care - give them plenty of room, and don't loiter.
That's nothing to do with the blind spots though. More to do with the fact that they've probably been driving for five days solid without a break and are actually asleep at the wheel.
Keep half an eye on anything you are passing on the motorway and don't be afraid to sound the horn if they start moving out on top of you or the flasher comes on while you're alongside them. That's what it's there for (to alert other road users to your presence). On hearing a horn nearby, they will usually stop whatever manouver they were doing and slow down a bit.
PostPosted: 20:59 - 08 Apr 2008    Post subject: Reply with quote
This is very true. No headlight under those circumstances lets them see your shadow against the bright sun. They used to camoflage daytime bombers in WW2 by illuminating the underside of them with floodlamps pointing along the wings.
On a slightly related point. I've been doing a fair bit of dusk/dark motorway riding lately and I've taken to moving about sideways a lot within my lane as I approach traffic. You can easily 'lose' a motorcycle headlight in the other ones behind you but a cars headlight can't move sideways like that. Gives the driver something unexpected to look at, his brain instantly pays more attention. The brain is more tuned to looking at movement than shape.
The last post was made 18 years, 205 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 128.51 Kb
