clutch out when starting?
superslick
PostPosted: 18:27 - 08 Apr 2008    Post subject: clutch out when starting? Reply with quote
My rs125 i the first road bike iv had so iv got to get used to not having a kick start Shocked. When in neutral iv noticed it starts alot quicker if i hold the clutch in, press and hold the starter and release the clutch (with the starter button still pushed in) at a slow to moderate speed.
Is it ok to do this? Is it going to cause any damage to the clutch or starter motor/starter gear?
aprillia rs125 gp-1 2004
Sparks!
Sir Tart-a-lot
PostPosted: 18:33 - 08 Apr 2008    Post subject: Reply with quote
If anything its better to start with the clutch in... but doubt it makes all that much difference... definetly wouldn't worry about it mate... I do it all the time...
Finglonga
PostPosted: 19:10 - 08 Apr 2008    Post subject: Reply with quote
Starting with the clutch in stops the gearbox from spinning and adding load to the starter . . . . . But when cold it will hardly make any difference as the clutch will drag with cold oil anyway.
Andy Sez....
F.Y.Y.F.F.
loply
PostPosted: 09:56 - 09 Apr 2008    Post subject: Reply with quote
The gearbox adds a reasonable amount of resistance on some bikes and IMO it's usually best to start with the clutch in.
It's a good habbit as it prevents potential mistakes with the bike being in gear.
Even with cold oil I think most clutches (certainly all the bikes I've had) will mostly slip rather than grip.
Yamaha SZR660 Caution to the wind, the throttle pinned!
Timmeh
PostPosted: 16:30 - 09 Apr 2008    Post subject: Reply with quote
I do it on my 125, because the starter is quite weak and the battery is tiny.
Does help a bit.
brucelivi
PostPosted: 18:54 - 09 Apr 2008    Post subject: Reply with quote
I have to pull the clutch in on my 1400 it will not engage the starter without it so  i would say its a good thing. Smile
The last post was made 18 years, 185 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 47.41 Kb
