heated grips, good or gash?
superslick
PostPosted: 19:11 - 09 Apr 2008    Post subject: heated grips, good or gash? Reply with quote
i know this is a silly topic to bring up with summer just around the corner, but has anyone ever had any experience with heated grips, can you actually feel the heat through thick bike gloves?
aprillia rs125 gp-1 2004
Blackwolf
Burgerfist
PostPosted: 19:19 - 09 Apr 2008    Post subject: Reply with quote
Good oh so very good, but I've been told there a lot better with bar muffs too
LeeR
PostPosted: 19:27 - 09 Apr 2008    Post subject: Reply with quote
My heated grips are factory fitted and I really rate them, one of the best things about them is, because they are so good you don't need really thick gloves, so you have plenty of "feel". I don't have muffs, but I do have handguards and this keeps some of the wind chill off. Thumbs Up
My claim to fame: Austin Vince nicked my pen...
calum17
PostPosted: 19:51 - 09 Apr 2008    Post subject: Reply with quote
get them. that's all there is to say.
i fitted 'roxter' ones to my bike (same as oxford really) and i use them quite often, i rode in extreme cold, wind and rain for 5 hours last month and had them on at first, after a while i decided that they werent helping, so i switched them off. i coudnt get them back on quick enough after a few minutes when i realised how much they did help. they may not always warm your hands up, but they certainly will stop them getting so cold. fit them, for the little cost you will get great gains.
Charlie
PostPosted: 19:55 - 09 Apr 2008    Post subject: Reply with quote
Fit them you will love them. I have ridden through winter using Autumn/spring gloves which aren't that thick really, but I had warm hands Smile
superslick
PostPosted: 20:59 - 09 Apr 2008    Post subject: Reply with quote
https://cgi.ebay.co.uk/OXFORD-HOT-GRIPS-HEATED-HANDLEBAR-HOTGRIPS-E-BAY-ONLY_W0QQitemZ290221106931QQihZ019QQcategoryZ25643QQssPageNameZWDVWQQrdZ1QQcmdZViewItem#ebayphotohosting
these the sort of things?
Charlie
PostPosted: 21:03 - 09 Apr 2008    Post subject: Reply with quote
Yep thats what I have got. Wire them straight to the battery as the manual says. Some people put relays in, except Oxford have advised against this as the heated grips might turn themselves off due to a lack of power.
kawakid
PostPosted: 21:31 - 09 Apr 2008    Post subject: Reply with quote
Got them on both bikes.
They are good in normal winter conditons
However when below zero and above 50mph (ie your doing 60 and its - 2) you can't tell they are on.
I've a twin and a 4.
pa_broon74
PostPosted: 21:37 - 09 Apr 2008    Post subject: Reply with quote
I fitted them to to my 125, big bike has them too but I haven't tried them as yet.
I got a cheap set off ebay, had to make some after-market adjustments (cheap chinese cable had a break.)
Anyway my point was, I think to get full effects from them you need some sort of wind guards, knuckle protectors or what ever they're called. The palms of my hands were always toasty but they do nothing for my finger tips.
Didn't catch anything.
Stelmer
PostPosted: 22:02 - 09 Apr 2008    Post subject: Reply with quote
Probably the best bit of kit you can buy. GET THEM. I got some Roxter grips from the NEC for £30. Gonna get some more this year as a spare set as I think the connectors are corroding as I left them exposed.....
They really make a difference in most winter conditions. I did 470 miles over the weekend in Wales. Snow, hail and and icy wind - they held up and although my finger tips got cold, my hands were not painfully cold. They were on full blast for most of the day too.
They turn themselves off when the battery falls below 11.5v. The bike will still start as I tested that when I got them. I wired them direct to the battery as this gives them access to a supply of 13v+ when the engine is running to ensure effective operation of the heat.
Ariel Badger
PostPosted: 22:15 - 09 Apr 2008    Post subject: Reply with quote
You will never know the joy of gradualy having feeling come into your hands after a long ride if you fit them, avoid.
binge
Emo Kiddy
PostPosted: 22:17 - 09 Apr 2008    Post subject: Reply with quote
If they did some form of heated element that goes inside the clip on bar id be interested.
But I run Renthal Grips. Simply because they are super skinny.
And Ive never come across a set of heated grips as thin as renthals.
Ben
alun111
PostPosted: 23:36 - 09 Apr 2008    Post subject: Reply with quote
They're very good for motorway journeys but for around town they're no good, as you're often using the clutch and front brake so don't get heat on your finger tips (definately the bits that get the coldest).
Mine turn off all the bloody time anywhere under about 30mph but I'm not sure why (they're not wired through a relay).
I'm going to invest in heated gloves next winter... no more cold hands then. I spent practically £100 on heated grips and good thick gloves.... for £120/£130 I could have got the perfect solution - heated gloves!
Will87
PostPosted: 03:08 - 10 Apr 2008    Post subject: Reply with quote
Ben
They do a set of elements, that are extremely thin, they go on the bar and the grips (whatever you want) go over the top, heating your choice of grips. Few american places do them, not sure bout in the uk, but i bet it's possible.
Finglonga
PostPosted: 11:51 - 10 Apr 2008    Post subject: Reply with quote
I don't have any thick gloves, I use my summer gloves through the winter with my heated grips. Thumbs Up
Andy Sez....
F.Y.Y.F.F.
Zen Dog
PostPosted: 12:16 - 10 Apr 2008    Post subject: Reply with quote
Is your interest in old bikes motivated exclusively by masochism? Just curious...
Zen Dog
weemo2007
PostPosted: 14:18 - 10 Apr 2008    Post subject: Reply with quote
Sounds as though i am missing out Confused My kids bought them for mothers day,,, and i haven't had them fitted yet Razz
MEMENTO VIVERE
remember to live life,,,, Theres always a better day than the day before...
Dreaming
PostPosted: 16:31 - 10 Apr 2008    Post subject: Reply with quote
I'm tempted to get some, are the wrap around ones good too or is it better to invest in the new grips completely?
The Tot
PostPosted: 23:17 - 10 Apr 2008    Post subject: Reply with quote
I took mine off and fitted renthals instead! Shocked In the coldest winters, i STILL got cold and had no feeling in my hands, so back to thick gloves for that homely comfort. I ran oxford grips too. The cable got snagged and screwed the grip up!
Never argue with autism
nynfortoo
PostPosted: 09:10 - 11 Apr 2008    Post subject: Reply with quote
I find if it's cold enough to warrant their use, I've already taken measures (Pathan lobster claw gloves, and HG neoprene overgloves) to negate their benefit.
They don't do anything for my fingertips or the backs of my hands; I imagine they would be MUCH better with muffs/guards fitted to reduce wind-chill without bulking up.
Peirre oBollox
PostPosted: 15:02 - 11 Apr 2008    Post subject: Reply with quote
if you have hollow bars try https://www.pollyheaters.com/ph400.htm
they use em on smowmobiles and are reasonably cheap to buy
brucelivi
PostPosted: 20:09 - 11 Apr 2008    Post subject: Reply with quote
Have Oxford grips on my 1400 would not ride without them .Loads of heat and it has a thermostat so can turn heat up or down. Never had it past half way even running from Berwick to Livingston in freezing fog on the way back from Newcastle. Thumbs Up
nrml76
PostPosted: 21:27 - 12 Apr 2008    Post subject: Reply with quote
Another vote for heated gloves here. I've had two pairs of oxford heated grips fail in 2 years. You need a pair of grotesque handlebar muffs in addition to heated grips if you plan to do regular long distance winter riding. Grips by themselves make it marginally bearable; not comfortable. As others have mentioned, your finger tips and thumb will still be frostbitten, and riding in traffic with your hands on the cold brake and clutch levers still remains a problem. Still, it's better than nothing.
Everyone who lives dies, yet not everyone who dies has lived. We take these risks not to escape life, but to prevent life from escaping us.
The last post was made 18 years, 219 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 118.77 Kb
