airbox mod 04 DT125RE
zetecy
PostPosted: 23:13 - 09 Apr 2008    Post subject: airbox mod 04 DT125RE Reply with quote
ive heard that removing something in the standard airbox makes the bike sound nicer, bit of induction noise of sumthing when bliping the thrrottle. Took some panels off and the seat and i could see like a snorkle i think, one snorkel above the airbox and one below. should i just forcefully rip the rubber snorkle off, i think its glued?. or do i have to remove a whole assesmbly of sum sort.
Cheers, Dave
binge
Emo Kiddy
PostPosted: 00:29 - 10 Apr 2008    Post subject: Reply with quote
If the bike is completely stock, Then it has been built and set up to run complete.
Removing parts of the Air box is just going to make it run lean. Which means it will be running hot. And will probably seize being a 2 stroke.
Put a different exhaust on it, Put a K&N air filter on it. Hell, Put Neon lights on it.
But after all is said and done, Its a 125.
"Induction" noise wont be much Cop.
Ben.
zetecy
PostPosted: 00:53 - 10 Apr 2008    Post subject: Reply with quote
yes it is stock but i do want to put a dep system on it. and carbon fibre reeds but im having trouble sourcing the parts at tho mo.
But do you think i could remove it and check the spark plug colour oftenly to make the correct mixture is running
The last post was made 18 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.61 - MySQL Queries: 13 - Page Size: 35.69 Kb
