Sintered Brake Pads Vs Normal Brake Pads?
LuckyDip23
PostPosted: 11:45 - 11 Apr 2008    Post subject: Sintered Brake Pads Vs Normal Brake Pads? Reply with quote
Mornin.
can anyone shed some light on the difference between sintered brake pads and "normal" pads?
what would be better for fast rd riding - would probably prefer better stopping power over longevity (within reason of course)t?
lastly can anyone reccomend a decent set of pads for my thundercat?
Thanks in advance
Gareth.
The Tot
PostPosted: 12:35 - 11 Apr 2008    Post subject: Reply with quote
I'll try and copy out what is written in this month's RIDE magazine since they have something about pads and compounds and such like (issue with used 600's comparison).
Normal brake pads use an organic compound, often ferritic metals are incorporated into the matrix (the cake in which the brake pad material comprises of) whereas sintered pads use treated ceramics which are designed to have a higher coefficient of friction (specially selected blends which are then effectively baked and fused) - they heat up a lot as a result, but means in wet weather can dispell the water better. Notice that sintered pads have heatsinks on the back to dissipate the heat. EBC HH's are common sintered pads or some people recommend Carbon Lorraine SBK.
Sintered pads last pretty long and provide a shaper response which would be good for fast road riding, although people would be put off by the initial bite.
At the moment, i've got Vesrah sintered pads in mine and they bite well.
I'll copy out the exact definitions when i get back.
Having said that, the heat MAY lead to disk warpage so keep an eye on that - that's the major downside of using sintered pads.
Never argue with autism
killa
Won't Shut Up
PostPosted: 12:43 - 11 Apr 2008    Post subject: Reply with quote
If bedded in properly it is pretty hard to warp a set of discs, but it can happen.
The initial bite can be harsh but this depends on your brake lines and setup. I have mine set to be a bit squishy so i don't shock myself when freaking out mid corner. Laughing
Sintered do last a fair time depending on your riding.
PostPosted: 15:50 - 11 Apr 2008    Post subject: Reply with quote
The main thing you'll notice in real world riding is sintered pads have more initial "bite" when you first apply the brakes and that they are unaffected by water on the disc.
Not all sintered pads are great. I had some EBC "red stuff" ones that were supposedly sintered but were utterly shite, faded in then faded out and barely worked in the wet at all.
I have used EBC HH ones for years and can't fault them. They do wear discs out more quickly though.
KTM Gordo
PostPosted: 18:29 - 11 Apr 2008    Post subject: Reply with quote
Often the best pads for your bike are (perhaps not unsurprisingly) the OE (original equipment) ones.
There's usually a reason why the manufacturer fits a certain kind of pad - they've done a lot of research on it too.
If you're doing something like racing or a lot of track days then you might want a pad better suited to that, but for day-to-day use, stick to OE.
They're usually not as expensive as you'd think.
Change is inevitable - except from a vending machine.
KTM 990 Adventure | KTM EXC 250 Racing | Land Rover Freelander SE Td4
PostPosted: 18:34 - 11 Apr 2008    Post subject: Reply with quote
"Ahh, Mr Susuki san. Which of these blake pads we use on newest bike?"
"Velly simple. I done a rot of research and these cheapest in whole catarogue. Maximise plofit."
iooi
PostPosted: 18:48 - 11 Apr 2008    Post subject: Reply with quote
Sintered on the front, standard on the rear. Thumbs Up
While Mr manufacture will have spent a lot of devolpment costs on many things break pads will be left to the pad manufactures. The issue is just how much the bike manufacture is prepared to pay for the pads.
We all know the OE parts is where they make their profits from, so why use theirs when you can get exactly the same part direct from the pad manufacture for less, and then get a better quality pad.
The last post was made 18 years, 179 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 55.85 Kb
