Bike wont start after fitting big bore kit
Ant132
PostPosted: 18:19 - 12 Apr 2008    Post subject: Bike wont start after fitting big bore kit Reply with quote
Bike was running fine (suzuki ts50) but i decided that it i would fit the 80cc big bore kit i had.
Went on fine no problems, but the shop adviced me that i would have to fit a larger gasket underneath (thicker) the avoid the possibility of the piston hitting the head as its alot wider and the cyl. head has a smaller hole that was only big enough for the standard piston.
Anyway, I did, everything was fine and i came to start it and it wants to go and starts up but dies straight away. Sometimes if i held it on full throttle it would stay on very low but it still wasnt really started just kept goin, when i let the throttle go it died.
So, From this i thought it may be fuel? So i checked everything, found nothing wrong so thought about the jet? I had the original jet (70) in it and so i changed it to 82 (only other size i have), Still nothing, just exactly the same.
I did a compression test and i was getting 100psi, when the old cyl.was giving around 130-140, so i thought this was odd and checked the gaskets underneath.
The shop advised a metal gasket (3-4mm thick) with the standard base gasket on either side, so that is what i did..
I changed this to 4 base gaskets made out of gasket paper (2 x 0.5mm and 2 x 0.8mm) as i thought the metal one was no good.
This turned out to be even worse and gave me around 80psi..
This is where im at now, ready to have another go tomorrow Smile
Any ideas? Thanks!
1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200
hmmmnz
PostPosted: 19:57 - 12 Apr 2008    Post subject: Reply with quote
have you changed your fuelling?? youve almost double the capicity of the engine, it stands to reason that you are going to need a whole heap more fuel,
have you changed the whole head? or just got a rebored original barrel?? if its an original then your port timings are going to be wrong/out and will require you to grind the ports
the humans are dead
I kick arse for the lord
Ant132
PostPosted: 20:09 - 12 Apr 2008    Post subject: Reply with quote
How would you go about changine the fueling? As for the barrel, no its a completely different barrell but doesnt fit the head so you have to make a gasket for it unless you have a differeny head.
Thanks
PostPosted: 20:28 - 12 Apr 2008    Post subject: Reply with quote
Figure-out your piston-head clearance by bolting the cylinder down without the head (use spacers under the head bolts/nuts taking care not to damage the surface). You can use a ruler across the top of the barrel or put the old stock gasket on there, and run the piston up to top dead centre to check for clearance. You need at least 1mm. I'd be surprised if you needed those spacers to be honest, as few pistons project above the top of the cylinder at the outside edge. If you think the clearance might be too close, roll some plasticine out to about 3mm thick then cut it into strips about 6mm wide and then cut the strips to about 20mm long. Place these on top of the piston at places you would expect to come close to touching then drop the piston in the bore, assemble the top-end then GENTLY turn-over the engine BY HAND until either the piston passes TDC without the plasticine touching or the plasticine is squisehd in the gap. Don't force it . This is called 'claying the head'. A thorough description is here:
https://www.c-speedracing.com/howto/claymotor/clay.php
MaybeGuy
PostPosted: 22:18 - 12 Apr 2008    Post subject: Reply with quote
are you getting a new crankshaft too? as i cant imagine piling 80% more power would be too good for a crank designed to take the impact of 50cc...
dont expect your bigend, crankshaft or crank seals to last long.
iooi
PostPosted: 07:19 - 13 Apr 2008    Post subject: Reply with quote
Stupid question time.....
Where you fitting these extra gaskets under the head ? Or at the bottom.
hmmmnz
PostPosted: 08:40 - 13 Apr 2008    Post subject: Reply with quote
thats not a stupid question! thats a good one,
if the gaskets are at the bottom, then the ports will be at a different height than what they are supposed to be Thumbs Up
the humans are dead
superslick
PostPosted: 20:18 - 13 Apr 2008    Post subject: Reply with quote
could be that its not getting enough fuel in to combust in the bigger cylinder hence it not firing and not starting?
aprillia rs125 gp-1 2004
Finglonga
PostPosted: 11:28 - 14 Apr 2008    Post subject: Reply with quote
They will be fine, it's not much more power so won't put much more stress on them.
Andy Sez....
F.Y.Y.F.F.
The last post was made 18 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.22 - MySQL Queries: 13 - Page Size: 64.98 Kb
