nsr125 rev problem
steve-h
PostPosted: 11:03 - 13 Apr 2008    Post subject: nsr125 rev problem Reply with quote
finally gotto get out and about on my nsr125r(2001 model
) this morning
and noticed that it doesnt want to pull past about 6500rpm
now i believe the nike to be unrestricted
i know there is not a plate in the inlet tract and pretty sure the exhuast is done aswell
what other restrictions are in place
current bike: honda cbr 600f
alains
PostPosted: 13:38 - 13 Apr 2008    Post subject: Reply with quote
did you fit the right cable in the right place (servo pulley) ?
download my file https://geneva-racing.com/~alains/NSRtips.doc and look on bottom page 9 and check if your valves move as shown in the picture
steve-h
PostPosted: 14:56 - 13 Apr 2008    Post subject: Reply with quote
cables are in the right place as per your file
when key switch is on the servo goes to lo and not hi as in the file
alains
PostPosted: 15:08 - 13 Apr 2008    Post subject: Reply with quote
is your bike a swiss import ?
steve-h
PostPosted: 15:11 - 13 Apr 2008    Post subject: Reply with quote
how would i tell that??
alains
PostPosted: 15:16 - 13 Apr 2008    Post subject: Reply with quote
pass me a pm with your serial . look between the yokes on a label you'll see your's ZDCJC22 then a letter (E=switzerland) then 0 and a letter or 1 (W=1998,X=1999,Y=2000,1=2001) then you have a F and 6 digits engine serial
steve-h
PostPosted: 16:56 - 13 Apr 2008    Post subject: Reply with quote
so we have found that my bike is a swiss import
the intake restrictor has been removed so has the exhaust restrictor
the rc unit is a TV78
jets are 138/42/65
what should the cdi unit be?
steve-h
PostPosted: 18:01 - 13 Apr 2008    Post subject: Reply with quote
i just found that my cdi unit is CI626
think there maybe an A at the end of the number
there is also a orange coming from the cdi and looped back into it
superslick
PostPosted: 20:07 - 13 Apr 2008    Post subject: Reply with quote
Not a spark restriction in the cdi is it? (rev limiter)
as i know on the rs's if you break a circuit board bridge in the cdi (only on certain models) it breaks the rev limiter.
just a thought id look into but wouldnt really reccomend it as it sounds like a cheap way to bollocks yer bike!
aprillia rs125 gp-1 2004
alains
PostPosted: 21:54 - 13 Apr 2008    Post subject: Reply with quote
the CI626A has 2 orange wires to insert a black box called "drossel" in germany . this will limit the speed at 80Km/H and allowed young people to ridde at 16 without a too expensive insurance . for normal use this CDI will limit your speed at 130 Km/H when you fit a shunt on these orange wires
the restriction on swiss imports is that a shunt is fitted on the servo-motor potentiometer and the servo will not move at all after it has initialize
to understand this look on my file page 17 https://www.geneva-racing.com/~alains/NSRtips.doc
The last post was made 18 years, 218 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 62.48 Kb
