fitting hot-grips ?
SVhovis650s
PostPosted: 08:01 - 14 Apr 2008    Post subject: fitting hot-grips ? Reply with quote
as the wires from the grips to the control box are very long, i was looking for some advice.......last time i fitted them, i just cable tied it in a bunch (which looked crap)
the only other thing i can think of, is to cut the cables, but then i would need to use differant connecters.
any ideas
Oh, what sad times are these when passing ruffians can say Ni at will to old ladies. There is a pestilence upon this land, nothing is sacred. Even those who arrange and design shrubberies are under considerable economic stress in this period in history.
hmmmnz
PostPosted: 08:30 - 14 Apr 2008    Post subject: Reply with quote
cut them solder the joint and cover it in heat shrink.
if you can open the controller, then you could redo all your connections in there.
the humans are dead
I kick arse for the lord
superslick
PostPosted: 19:48 - 14 Apr 2008    Post subject: Reply with quote
either that or just solder them, put them in a connecting tube and crimp it. but heat shrink would probably be best as its the most waterproof.
If you have any problems getting heat shrinks send me a message and ill pocket afew from work and post them up Thumbs Up
aprillia rs125 gp-1 2004
SVhovis650s
PostPosted: 22:37 - 15 Apr 2008    Post subject: Reply with quote
i dont think your meant to shorten the cables, as they are that lenth so they donk cook the grips.
so i was told?
The last post was made 18 years, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.03 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 40.44 Kb
