Fazer 600, not starting, not even trying!
danclarkie
PostPosted: 15:17 - 13 Apr 2008    Post subject: Fazer 600, not starting, not even trying! Reply with quote
Hello,
As some of you may be aware my fazer as nicked last month
https://www.bikechatforums.com/viewtopic.php?p=1755655#1755655
whn it was recovered it was thankfully fairly ok and had only had its igntion hotwired and locks forked.
Having sent the igntion off to be soldered and insulated and so on it put it back together only to fnd that the igntion comes on fine, horn works, all lights and dials appear to be working fine however its not showing the N light, and its also not starting up when you hit the electric start button.
Can be pretty sure its in neutral as i can push it round the garage and so on. When i collectd it from the recovery garage i drove it home fine and all was working (all be it 'hotwired')
Completely out of ideas and cast myslf humbily to your good selves
Thanks Very Happy
Bah Humbug
superslick
PostPosted: 20:12 - 13 Apr 2008    Post subject: Reply with quote
is the starter itself turning the starter gear? try bumping it.
aprillia rs125 gp-1 2004
iooi
PostPosted: 20:23 - 13 Apr 2008    Post subject: Reply with quote
Side stand/clutch switch.
Could be that they have really messed the wires up.
Could it be that it needs the N light to be on to allow starter to work ?
Somehow they sense netural, could it just be power to that bulb it reads.
danclarkie
PostPosted: 16:13 - 14 Apr 2008    Post subject: Reply with quote
Ive tried it with the clutch in and sidestand up stil nothng, the starter motor isnt turning no its not doing anything. Ive checked all the wires have been soldered back correctly so that the same colour sleeves match.
Still no idea Sad
Bah Humbug
tofu-wtf
PostPosted: 17:13 - 14 Apr 2008    Post subject: Reply with quote
engine fuse Question
Eagles may soar.............but rats don't get sucked through jet engines!!
1999 ZX6r G1.....it makes me smile Very Happy
danclarkie
PostPosted: 12:00 - 15 Apr 2008    Post subject: Reply with quote
Pretty sure ve checked all the fuses i can find in in, even the two 30A ones that were hidden away.
I cant help bt think its related to the "N" light not coming on.
Tried bump starting it yesterday and only ended up leaving 2 foot of bridgestone on my garage floor Sad
Bah Humbug
mr.kris
PostPosted: 13:53 - 15 Apr 2008    Post subject: Reply with quote
ware abouts you live mate i may be able to help?
TS50X---CM125---MZ150---Z250---RS125---ZXR250---BANDIT600---TRX850---TL1000S---CBF600---ZX6R---BANDIT1200S---CG125---VFR800---CBR1000F---CG125---CG125---CB900F---CB900F---CG125---TUONO1000R---KLR600---GSX1300R HAYABUSA---VFR400NC30---BANDIT1200---CG125
HAYABUSA now in use!
The last post was made 18 years, 215 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 53.69 Kb
