Compression Loss..
Ant132
PostPosted: 17:29 - 14 Apr 2008    Post subject: Compression Loss.. Reply with quote
Has anyone used eBay gasket paper, the cheap £5 for 8 sheets or so. Is it any good for base gaskets on barrells?
Ya see, the problem is my bike was running perfect until the the typical foolish youth in me came racing to the surface and i decided to fit a big bore kit.
So i used new gaskets from what i cut out of this gasket paper, and when i fully re-assembles the top end it had compression of about 80-100 on the gauge so was no good and never started.
Spent the weekend fiddling with it and several top-end rebuilds later i was no further and decided to re-fit the original and see how it was.
Still using the gasket paper, i fitted up the old piston and cylinder and off i went. Started ok but cut out, started again and left to idle, heard a popping noise, and then it cut out.
Wouldnt start again so gave it a bump and it started, (suggesting compression, correct?)
So then it started pouring down and i had to pack up.. So back on here for some advice Smile
So d'ya reckon them gaskets will be naff then or should i look else where, i also noticed the studs that the barrel and head go over, 2 of them where starting to tighten and then went loose again. So, i think theyll need replacing, (i have spare ones) but would these cause dramatic compression loss aswell?
When the bike cuts out, its like it goes to settle down at 1.5k revs and then slowly cuts out.
Cheers guys!
1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200
Timmeh
PostPosted: 17:34 - 14 Apr 2008    Post subject: Reply with quote
you've got no chance of getting any compression if you can't torque the head bolts to the right pressure.
Ant132
PostPosted: 17:41 - 14 Apr 2008    Post subject: Reply with quote
Right! 2 are fine the other 2 are just turning and not tightening properly, most likely the nut is turning the stud and not on the thread. Hopefully i can sort something out and the thread in the crankcase isnt knackered.
Cheers mate!
PostPosted: 17:43 - 14 Apr 2008    Post subject: Reply with quote
You will have pulled the thread out of the casings. You'll be needing to fit a timesert or helicoil in order to re-fit the studs.
superslick
PostPosted: 19:40 - 14 Apr 2008    Post subject: Reply with quote
did the big bore kit not come with gaskets tucked right inside the box or in the pack with the instructions? i bought an 80cc polini kit for this supermotard i had a while back and that had all the gaskets shoved in the middle of the fitting manual.
aprillia rs125 gp-1 2004
Rockhopper
PostPosted: 21:19 - 15 Apr 2008    Post subject: Reply with quote
Base gasket thickness is critical for getting the compression ratio right, to thick a gasket may be your problem. However if its too thin they you may even end up with the piston hitting the head.
Ant132
PostPosted: 22:13 - 15 Apr 2008    Post subject: Reply with quote
Thanks for replies..
I think im just going to stick with original now, Gasket set ordered and helicoils 6x1mm for studs.
Do you need that tool with it to compress or can you get around it somehow?
Ant.
PostPosted: 05:28 - 16 Apr 2008    Post subject: Reply with quote
You must use the tool, though they are quite cheap. Alternatively, there might be enough room to drill & tap for 8mm studs. You'd have to drill the head & barrell also of course.
The last post was made 18 years, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 57.68 Kb
