Couple of thoughts about my VFR (boring)
PostPosted: 20:43 - 14 Apr 2008    Post subject: Couple of thoughts about my VFR (boring) Reply with quote
I was having as think about a couple of things. No real point to this post other than thinking out loud.
You know how more modrn Hondas, and particularly VFRs have a reputation for eating reg/rec units? Well, I have a 1997 VFR750 and one of the guys in my club has a 1998 VFR800. Both bikes have done over 30k miles, both bikes are on their original reg/rec and their original battery. I was musing about why this should be.
Couple of things spring to mind. One is that these must be two of the only VFRs in the country without heated grips fitted.
The other thing is they are almost exclusively used for long runs at weekends. If they go out, it would be rare for them to do anything less than 150 miles at a time. Both bikes are used in this way all year round.
Makes me wonder if it's simply a case of the battery never really running down much, it always stays well topped up so there is minimal current passing through the charging system.
My other thought was an idea I had to save some money on tyres. I regularly run about 150 miles between here and my girlfriends house in York. Mostly dual carriageway, 'tis not doing my 021s much good in terms of squaring off the rear. It occurrs to me that I have a single sided swingarm and high level exhaust, as such it takes all of 30 seconds to change the back wheel.
I'm keeping my eye out for a spare wheel, I can stick a touring bridgestone on this then I can have the 021s for touring on twisties and a much harder one for straight line work. I can just put more air in the front for long-haul stuff.
veeeffarr
PostPosted: 20:51 - 14 Apr 2008    Post subject: Reply with quote
Interesting about the reg rec. I have the 00 model which has loads of upgrades from the 98 99 model including a revised reg rec. Good idea about the wheels. Although I use pilot road 2's and they've not squared off at all in 5000 miles. Awesome tyres.
veeeffarr
PostPosted: 20:53 - 14 Apr 2008    Post subject: Reply with quote
I don't have heated grips either. Although I replaced the battery at the start of winter
mr.z
PostPosted: 22:30 - 14 Apr 2008    Post subject: Reply with quote
Out of interest, how hot do they get these reg/recs?
I know some get very toasty.. What is it in them that fails? Confused
gmanxiii
PostPosted: 22:56 - 14 Apr 2008    Post subject: Reply with quote
Weird my first VFR400 had done about 21k miles (that was written off in accident) and had an original honda rec that i poached after the modded one from god knows what bike went on my 2nd vfr. Covered another 8k miles since and its been fine.
I kills hondas
VFR400NC30 > ZZR600 > CBR600FX > CBR1000rr
V2
PostPosted: 00:54 - 15 Apr 2008    Post subject: Reply with quote
Ive got a vfr and friends have had vfrs/rvfs none of our reg/recs have blown but when it was running i only used it on longer trips, maybe you are on to something here.
tatters
Exxon Valdez
PostPosted: 06:25 - 15 Apr 2008    Post subject: Reply with quote
I had the same VFR as you stinkwheel and before it was destroyed by a mini last year it had 70,000 miles on the clocks and was still on its first reg/rec.
Most reg/rec normally blow on the 400,s such as my NC24 due to its posion near the rear cylinders and that it does,nt have any form of heatsink on the unit so they overheat very quickly.
EuropeanNC30R...
Gay Hairdresser
PostPosted: 08:28 - 15 Apr 2008    Post subject: Reply with quote
The 400 reg/recs themselves aren't that bad, it's more the positioning of where they are (close to the rear cylinders where the frame gets egg-frying hot).
If a VFR400 hasn't eaten one already then it's about to.
veeeffarr
PostPosted: 08:42 - 15 Apr 2008    Post subject: Reply with quote
https://www.bikersoracle.com/vfr/forum/showthread.php?t=41313
Wonder how accurate that is...
doggone
PostPosted: 09:23 - 15 Apr 2008    Post subject: Reply with quote
This seems as good an explanation as any why some bikes have the problem.
EuropeanNC30R...
Gay Hairdresser
PostPosted: 11:02 - 15 Apr 2008    Post subject: Reply with quote
I would have thought running heated grips could extend the life of the reg/rec as it has less excess current to dissapate?
angryjonny
PostPosted: 22:20 - 15 Apr 2008    Post subject: Reply with quote
I replaced the reg/rec on my VFR on Sunday - it's at least the 3rd one that this bike has had.
I don't think the reg/rec problem is directly to do with the current being used or the amount they're ridden. They just get hot hot hot. Indirectly, longer trips mean open roads and higher speeds so the airflow keeps the unit cool. Commuting, particularly around London as I do means sitting in traffic watching your voltage regulator melting.
Time to invest in a 12v CPU fan I reckon - can't be too hard to hook up to the reg/rec unit.
veeeffarr
PostPosted: 22:55 - 15 Apr 2008    Post subject: Reply with quote
Why don't you just put the fixed reg rec on it? Or one from a FiY/Fi1?
(Not having mine Very Happy)
T
angryjonny
PostPosted: 07:55 - 16 Apr 2008    Post subject: Reply with quote
This is the first one I've personally replaced. Hopefully it's up to the job.
veeeffarr
PostPosted: 08:17 - 16 Apr 2008    Post subject: Reply with quote
Does it have SH689DA or SH579C-12 written on it? if it's SH579A-11 you've replaced it with another unreliable one Smile
Toby
angryjonny
PostPosted: 08:23 - 16 Apr 2008    Post subject: Reply with quote
Couldn't tell you from memory, and I'm not taking all the fairing off again to check. When the battery stops charging I'll know it's a duffer.
veeeffarr
PostPosted: 08:33 - 16 Apr 2008    Post subject: Reply with quote
No worries mate, you only need to lift the seat up to see it though Smile
T
The last post was made 18 years, 221 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 93.31 Kb
