HI how to derestict an nc 24
traitor
PostPosted: 18:50 - 13 Apr 2008    Post subject: HI how to derestict an nc 24 Reply with quote
HI all
have spent the last hour looking on the forum for the answer to this and not found one, how to derestsict honda nc 24 (grey) could some one please help.
have read somewhere that its in the speedo and all have to do is bend and snap, but not cut the wire as will miss fire is this true?????
MIke
hmmmnz
PostPosted: 18:53 - 13 Apr 2008    Post subject: Reply with quote
i gather you still have kmh clocks??
if so then buy an kmh to mph converter, that way you'll never reach the 180kmh on the clock, (the point when the restrictor kicks in)
job done
the humans are dead
I kick arse for the lord
PostPosted: 19:42 - 13 Apr 2008    Post subject: Reply with quote
+1 for what hmmmz says.
You can open up the clocks and bend the offending piece of metal out the way like you can on NC30's, but just fitting an MPH converter is much easier.
Jenks
PostPosted: 10:49 - 14 Apr 2008    Post subject: Reply with quote
As Above, all you do is fit one of those KMH to MPH (blue thingy) Converters to the top of the speedo into the clocks.
1978 MZ TS 250 1 Supa 5
1992 yamaha fzr1000 exup
1998 aprilia af1 sintesi
traitor
PostPosted: 19:37 - 14 Apr 2008    Post subject: Reply with quote
cheers
for the help, can anyone tell me where i can get a mph converter from??
binge
Emo Kiddy
PostPosted: 21:21 - 14 Apr 2008    Post subject: Reply with quote
Motrax sell them. But im not convinced the NC24 was restricted.
I may be wrong though.
And on the NC29, if you cut the wires or unplug them from the clocks it fires on 2 cylinders at anything over 5k rpm.
Ben
PostPosted: 06:20 - 15 Apr 2008    Post subject: Reply with quote
What he said. Wink
traitor
PostPosted: 08:03 - 15 Apr 2008    Post subject: Reply with quote
ok so how come at about 110mph its stops firing on 2 cyclinders??
OR COULD IT BE SOME THING ELSE?
sickpup
Old Timer
PostPosted: 09:31 - 15 Apr 2008    Post subject: Reply with quote
Because you've never serviced it and the plugs are fouled?
The NC24 I have is not restricted and they stopped making before the restriction came in in 1989.
traitor
PostPosted: 16:55 - 15 Apr 2008    Post subject: Reply with quote
ok was servied last week, new plugs oil and filter, as now only had it a week so could that of been it??
cheers
for all the help
mike
traitor
PostPosted: 17:10 - 15 Apr 2008    Post subject: Reply with quote
hi have just found this, and now a bit confused as being told its not restricted and finding this not shore what now
https://www.vf750fd.com/motorbikes/NC24.html#per
at the bottom.
cheers
mike
The last post was made 18 years, 215 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 75.52 Kb
