Oil leaking from Generator Cover
spike_Alike
PostPosted: 17:23 - 16 Apr 2008    Post subject: Oil leaking from Generator Cover Reply with quote
Long story short, bikes been down the road and now oil is leaking from the Generator cover. What do I need to do to sort it, and what parts do it need? Question Been researching around online and its confused the life out of me!
Bandit 600
yankeedoodle
PostPosted: 17:29 - 16 Apr 2008    Post subject: Reply with quote
my bandit 6 is doing that. the previous owner packed it with some silicone but its still leaking a bit and it gets on my foot while I'm riding.
im going to be replacing the cover asap.
Bandit 600
spike_Alike
PostPosted: 19:33 - 16 Apr 2008    Post subject: Reply with quote
Vincent wrote:
Usualy, the first thing is to take the cover off and check the surfaces for any gouges or bits of old gasket. Don't use a screwdriver to force it off, it could damage the mating surfaces and this might be why it's leaking in the first place. While pulling it outwards with one hand, gently tap it all the way around with a wodden mallet or similar. Not sure if you'll need to drain the oil, you can sometimes get away with leaving the oil in if you lean the bike over. if the surface are ok, just try a new gasket, probaly about £1.75. If it's for the ZXR, try Cradely Heath Kawasaki. when sticking it back together, tighten the screws up equaly. Are there any wires coming out of the cover?
Thanks mate, I've got a Gasket on the way Thumbs Up
So its just a case of draining the oil (gonna struggle to get it leaning enough I think), carefully getting the cover off without prying it open, checking it over and changing the gasket and possibly cover if needed ?
Nah mate no wires hanging out, the outside of the cover is scratched but I cant see any obvious holes or anything.
Bandit 600
The last post was made 18 years, 180 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 45.58 Kb
