Honda CG125 --> I need some help!!!!!
joePC
PostPosted: 22:06 - 13 Feb 2004    Post subject: Honda CG125 --> I need some help!!!!! Reply with quote
Hi,
I'm just about to buy a second hand Honda CG125 its been in storage for the past 4 years.........it starts but stalls etc..... The guy im buying it off says it needs its carburator cleaned and a new battery, Im new to bikes and want to use this bike as a good learning tool.
Im just wondering would this bike be OK if I got it serviced etc.....
It has 30,000 on the clock....
Thanks joePC
Sparks!
Sir Tart-a-lot
PostPosted: 22:08 - 13 Feb 2004    Post subject: Reply with quote
Hey, good choice for starting on a CG, they may not be as nice as the NSR, but cheap and excellent to learn on until you can afford a proper bike and do your full test.
From sounds of it, yes a carb clean and service will most probably fix it. Make sure it has petrol and there are no blocks in the fuel lines etc, get the carbs cleaned out, new spark plugs and an oil change and try again.
How much are you paying? As it's really not worth much.
joePC
PostPosted: 22:10 - 13 Feb 2004    Post subject: Reply with quote
After all the talk I got down to £250.........Is this a fare price?
Thanks joePC
carvell
Scuttler
PostPosted: 22:16 - 13 Feb 2004    Post subject: Reply with quote
Bear in mind that 30,000 is a lot of miles for a 125 - there will be a bit of life left in the engine though, maybe.
Maybe try offering £300 - £350 for the bike with it serviced?
Yamaha TDM 850
Sparks!
Sir Tart-a-lot
PostPosted: 22:20 - 13 Feb 2004    Post subject: Reply with quote
£250, I'd personally say that's too expensive for a non-running 125 CG with 30k on the clock.
I wouldn't pay more than £150, but then I'd only buy a 125 if it was cheap and to sell it on!
£350 with it serviced and running sounds fair though, but CG's aren't worth much as they are under £1000 brand new if I remember correctly.
mr.z
PostPosted: 01:32 - 14 Feb 2004    Post subject: Reply with quote
ahhh the cg, up untill 4months ago i had one,
never once had a problem with it in the year i owned it...
its not likeley to need allot to fix it, probably just mankey carbs/fuel line? if you do get it then have a major service done on it straight away, then you will find any potential problems with it, if you can do it yourself (just make sure you have a haynes manual!) then its going to be cheeper, there isn't allot that can go wrong with the cg, and new bits are as cheep as anything! (the tyres are cheeper than some bycicle tyres)
you can buy a replica cg (hondogu or something good quality, basicly the same just the older style) for £1000 the new model honda is about £1300, wich has disc brakes (trust me you want them) and an electric start (ooooh!) the models of the last 3/4 years had an electric start as well i think...
but they are damn fine (if not exciting) bikes, did some fairly serious miles on mine (went to leeds festival on it, interesting is the word) though its not as comfy as a biger capacity bike its not bad for a 30year old design! 99% of bike schools can't be wrong!
*also, i did my cbt on a cg with 40k on the clock, might have even been around once before! they get a daily thrashing, serious abuse from learners, draped, fierce bad gear changes general knocking about, but it felt the same to ride as mine which had something like 26k on Smile
G1_
PostPosted: 07:39 - 14 Feb 2004    Post subject: Reply with quote
I don't think 30k miles is to bad for a 4 stroke 125. If it was a 2 stroke it would be another matter.
CG's go for ever if they are treater even slightly well!
Robby
Dirty Old Man
PostPosted: 10:18 - 14 Feb 2004    Post subject: Reply with quote
Go for it. They do come up cheaper, but not masses cheaper, and you'll be able to sell it for the same money.
30k is ok. Worst case scenario is you need a new set of piston rings, AFAIK its a pushrod bike so unless the honda monkeys were feeling particularly sadistic that day (a la CX500) there should be no camchain to snap.
joePC
PostPosted: 13:43 - 15 Feb 2004    Post subject: Reply with quote
Thanks everyone for the info im gona collect it on monday, should have it up & running by wedsday ((hopefully))
Thanks joePC
mr.z
PostPosted: 19:10 - 15 Feb 2004    Post subject: Reply with quote
if you have any specific CG questions i might be able to help Smile good luck with it anyways Thumbs Up
mtthwpez
PostPosted: 09:17 - 16 Feb 2004    Post subject: Reply with quote
30000 miles is nothing for a cg125 engine its probably the most bullet proof engine i've ever come across!
The last post was made 22 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 66.58 Kb
