please help me with my kawasaki vn 1500 problem
vnruss
PostPosted: 16:29 - 21 Apr 2008    Post subject: please help me with my kawasaki vn 1500 problem Reply with quote
I have recently rebuilt the top end on the engine and i have done everything by the book. The engine is now back in the bike for the third time and i am still having problems. The timing has been double checked, But still backfiring and loss of power. We have checked the most obvious possible faults but now we are clutching at straws...please please help. Crying or Very sad
sickpup
Old Timer
PostPosted: 17:53 - 21 Apr 2008    Post subject: Reply with quote
Did you put the balance caps back on the cards?
Ichy
PostPosted: 18:05 - 21 Apr 2008    Post subject: Reply with quote
Is yours fuel injection or carb?
You've probably done it already.
Cams lined up correctly, valve gaps, compression test?
Check carbs are seated correctly, manifold and link to air box is tightened up correctly. Vacuum pipes are all attached with no splits. Any other vacuum pipe take off points are blocked.
Checked float levels, pilot screw and jet? plug chop?
What have you done to the bike, if anything? New pipes, filter?
Have you fitted new plugs? Checked coils?
I don't think I'm far from you if you need any help.
ZaphodBeeble
PostPosted: 23:16 - 22 Apr 2008    Post subject: Reply with quote
Ichy wrote:
compression test?
This should definitely be your next step! Thumbs Up
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
The last post was made 17 years, 195 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.34 - MySQL Queries: 15 - Page Size: 39.44 Kb
