aprilia rs 125 help
jezrob81
PostPosted: 19:31 - 28 Apr 2008    Post subject: aprilia rs 125 help Reply with quote
hi there just wondering if there is somebody who could give me a little bit of advice i was travelling down the road at a high speed when my back wheel locked up and cut out and came to a standstill proceeded to try and start it it turns fine just dosnt fire and yes there is spark there was a smell of burning water if that makes any sense but has not lost any fluids really hoping it may be a simple fix
2006 _p1
PostPosted: 19:43 - 28 Apr 2008    Post subject: Reply with quote
looks like you blew your engine. get the barrel off and have a look maybe its just the rings gone and have a look at the barrel for scores. dont keep trying to start your bike you will just do more damage.
jezrob81
PostPosted: 19:57 - 28 Apr 2008    Post subject: aprilia rs 125 help Reply with quote
just the top or knackered hole lot? Sad Sad Sad
5v3d3b0
PostPosted: 20:00 - 28 Apr 2008    Post subject: Reply with quote
If anything it'll be the top unless you were doing 100 mph flat out for 20 minutes. But the top would have broken before those 20 minutes pass anyway,m so yeah, top end
Robby
Dirty Old Man
PostPosted: 20:14 - 28 Apr 2008    Post subject: Reply with quote
Do a compression test before you strip it, but it sounds like a classic seizure. Assuming it is you'll need to pull the top end down to see, you'll probably need a piston kit and a barrel. Head should be ok, and but sure to check for vertical play in the con rod while you have it pulled apart.
Don't try to reuse gaskets.
The "burning water" smell is a bit of a worry. Only thing that would smell like that is head gasket failure, but to smell it you need to have the bike running and warmed up.
jezrob81
PostPosted: 20:15 - 28 Apr 2008    Post subject: aprilia rs 125 help Reply with quote
not to bad then i thought it would just be the top think its time to go bigger Laughing Laughing Laughing
jezrob81
PostPosted: 18:11 - 06 May 2008    Post subject: aprilia rs 125 help Reply with quote
completly knackered it lot of play in the conrod loads of metal filings in the chamber and stuck to the top of the piston and a chunk out of the barrel someting tells me it dont look good for my little rs
Damon
PostPosted: 18:33 - 06 May 2008    Post subject: Reply with quote
can i buy it off you?
I need some spares for the one im building
2006 _p1
PostPosted: 18:37 - 06 May 2008    Post subject: Reply with quote
if you need some spares i have a rs 125 133 engine. all good except one of the clutch spring things snapped.
Damon
PostPosted: 20:01 - 06 May 2008    Post subject: Reply with quote
what year model is that off?
and how much? PM me
2006 _p1
PostPosted: 20:17 - 06 May 2008    Post subject: Reply with quote
Pm'd Thumbs Up
dardappa2004
PostPosted: 20:32 - 06 May 2008    Post subject: Reply with quote
definayl need a new top end happened to me aswell mate
jezrob81
PostPosted: 21:56 - 06 May 2008    Post subject: aprilia rs 125 help Reply with quote
top end is no problem to replace its the bearing that holds the conrod that i think is goin to be the problem not a clue on sortin that
2006 _p1
PostPosted: 06:36 - 07 May 2008    Post subject: Re: aprilia rs 125 help Reply with quote
Rip it out and get it rebuilt! Ive just sent mine out Mr. Green
The last post was made 18 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 77.56 Kb
