Autosol
yankeedoodle
PostPosted: 12:02 - 01 May 2008    Post subject: Autosol Reply with quote
just how good is it? I fancy using some to clean up the 125 a bit before I sell it. No doubt it will be handy to use on the bandit too.
Can it get rid of surface rust? Theres a bit on my exhaust which needs to go if possible
cheers
Bandit 600
t121anf
PostPosted: 12:13 - 01 May 2008    Post subject: Reply with quote
theres "not for road use" on mine that has to go, but i am concerned that it'll leave a mark which will make it obvious i've buffed it
The Tot
PostPosted: 12:15 - 01 May 2008    Post subject: Reply with quote
You'd need to use wire wool to remove surface rust and go up the grades of wet and dry paper from about 80-800 (depending on if you want it finished ultra shiney, you can go up to 1200). Autosol mainly polishes out the surface of the metal and produces a mirror finish. You can't expect much if you're applying it straight to the rust. Also, what material are you applying autosol to? If it's mild steel on the exhaust, then simply get BBQ or heatproof/high temp paint. If the rust has removed some chrome on the exhaust, then you're out of luck mate.
Never argue with autism
andi
PostPosted: 19:05 - 01 May 2008    Post subject: Autosol Reply with quote
its good stuff Thumbs Up
https://i16.photobucket.com/albums/b24/andipicture/Motorbikepics026.jpg
https://i16.photobucket.com/albums/b24/andipicture/Motorbikepics001.jpg
Before: Suzuki GT 185. Honda Superdream 250. Yamaha RD350LC. Suziki RG250. Yamaha FZS600. Honda CBR600F3
Now: Honda Fireblade 929
ZRX61
Victor Meldrew
PostPosted: 02:39 - 02 May 2008    Post subject: Reply with quote
Found a place in the US that sells it in 1kg cans Smile
m0l0t0v
PostPosted: 12:44 - 02 May 2008    Post subject: Reply with quote
Ship me some, I'm gonna need a lot Laughing
lozzypop1
Certified MILF!
PostPosted: 02:05 - 03 May 2008    Post subject: Reply with quote
And T-Cut, Don't forget the T-Cut.
Stevep
PostPosted: 06:19 - 03 May 2008    Post subject: Reply with quote
Use it only if you want completly knackered chrome as it is an acid and it will do more harm than good and will eventually cause severe pitting you are better using auto glyn products and plenty of elbow grease
Harleys run Forever
MattEMulsion
PostPosted: 08:21 - 03 May 2008    Post subject: Reply with quote
If you are using it on a large area that is in bad condition then autosol can turn into long hard work. It gets good results though. Thumbs Up
Yamaha YZF-R6
m0l0t0v
PostPosted: 13:38 - 03 May 2008    Post subject: Reply with quote
I won't be needing it Wink
lozzypop1
Certified MILF!
PostPosted: 14:07 - 03 May 2008    Post subject: Reply with quote
I DO however, think you need a custom title... M0l0t0v - 'shaken not stirred' Wink
m0l0t0v
PostPosted: 14:11 - 03 May 2008    Post subject: Reply with quote
Dance!
I seriously want one know! Laughing
If you make it happen... Wink
J.K.R
PostPosted: 14:39 - 03 May 2008    Post subject: Reply with quote
Awesome stuff. Have to use it every other week on my bike (Completely polished wheels, Stainless can + link pipe, Clutch cover, Stator + Pickup covers, Sprocket cover, Yokes, Risers, Rearsets and the levers)
Looks brilliant all polished up, One shower and its all dull again Rolling Eyes
Getting all powdercoated in the winter Twisted Evil
www.oldskoolsuzuki.info
Stevep
PostPosted: 16:41 - 16 May 2008    Post subject: Reply with quote
As said before autosol eats aluminium and pits which is why once you use it you have to reuse it on virtually a weekly basis
Have just found a better alternative and its recommended by a lot of major manufacture and it is made by Auto Glyn and it is a metal polish absolutely superb and when used actually leaves a protective wax coat on top and rain water runs off it
Harleys run Forever
kitty kat
PostPosted: 17:15 - 16 May 2008    Post subject: Reply with quote
with Stevep on this one, I would never even dream of using Autosol on my pride & joy, you are asking for trouble.
I use Auto Glym products, they give a fantastic result without eating away at the chrome or stainless bits on your bike.
Syx
PostPosted: 20:17 - 16 May 2008    Post subject: Reply with quote
+1 for AutoGlym Metal Polish. Fantastic stuff.
and
PostPosted: 22:00 - 16 May 2008    Post subject: Reply with quote
ZRX61
Victor Meldrew
PostPosted: 16:30 - 17 May 2008    Post subject: Reply with quote
Do NOT use anything harser than 1500 on chrome!!
80?? are you taking the piss?
kitty kat
PostPosted: 16:51 - 17 May 2008    Post subject: Reply with quote
Found this about autosol.
It, as stated, also contains ammonia which can cause long term cracking in metals.
It is an abrasive, so theoretically that tells you that it removes a layer from whatever you are polishing, used over a period of time that means any lacquer on the part will be removed, leaving it unprotected.
tutton
PostPosted: 18:19 - 17 May 2008    Post subject: Reply with quote
Let him use 80 see if he gets a nice surprise Laughing
i personally wouldnt wet and dry chrome below 1000.
and at kittys post, most things that get polished are either stripped/sanded of paint so laquer is automatically gone otherwise your polishing paint..
The last post was made 18 years, 139 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 109.76 Kb
