Running Rich!
MillaMeter
PostPosted: 10:04 - 04 May 2008    Post subject: Running Rich! Reply with quote
Hi,
I own a lovely ZXR400 L2 I had a lil off 2 weeks ago which done some cosmetic damage, (no big deal)
But since as the fairings were off, I decided to change the headers from the orginal 1s to S/S 1s. The bike was set up on a Dyno a month back putting a big hole in me bank. But now that the new headers are on, it's thrown all that Dyno work out the window Sad
Could different pipes really throw the carbs out? I whipped the plugs out only to find they're all black (rich) Also would a air leak cause any problems where the downpipes meet the engine?
Regards
Rich
Currently Own:
2010 Kawasaki ZX6R RAF Performance Edition / 2008 Kawasaki Ninja 250 K8F
Ichy
PostPosted: 10:12 - 04 May 2008    Post subject: Reply with quote
Headers on their own shouldn't change the mixture but a leak from the exhaust port will.
Did you drop the bike after the dyno setup or before? If after then its possible the floats or other carb internals have been disturbed.
MillaMeter
PostPosted: 10:23 - 04 May 2008    Post subject: Reply with quote
After i stacked it, i picked the bike up and rode it home. It was still running sweet after the spill. Just when i changed the headers it's not reving past 3000. If there is a leak at the outlets, whats the best way to see it?
regards
rich
Currently Own:
smeg918
PostPosted: 23:28 - 04 May 2008    Post subject: Reply with quote
Hi, if it's leaking at the headers you should be able to hear it, did you replace the outlet gaskets, even if it is leaking it's strange it won't rev past 3000. guessing here but could there be a blockage in the headers !!!! some packaging or something !!!!. If the plugs are black it's running too rich air leaks tend to weaken the mix and cause some popping/backfires. I know it's a pain but try sticking the old headers back on see if the prob goes away
The last post was made 18 years, 173 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 40.02 Kb
