| benvanwell |
 benvanwell Nitrous Nuisance
| 2006 _p1 |
 2006 _p1 Crazy Courier
| benvanwell |
| 2006 _p1 |
| benvanwell |
| 2006 _p1 |
| Ichy |
 Ichy World Chat Champion
| benvanwell |
| timjim |
 timjim Trackday Trickster
| benvanwell |
| benvanwell |
| StealthDJ |
 StealthDJ Nova Slayer
 Posted: 10:56 - 07 May 2008 Post subject: |
I had something very similar to this manifest on my SV.
About six months after I bought it, some little shite tried to chisel the ignition (and failed), but damaged the key flap in the process. About a year and a half after that, I started getting all kinds of fun. Sometimes it cut out at high revs, other times, I could sit and spin the starter all day and get no spark.
Turned out, the contacts in the bottom of the ignition switch had virtually given up, particularly one that is an earth from the CDI. Without that one earth line being grounded, you get no spark at all, but everything else, including the starter, worked fine.
Try some contact cleaner in the ignition and switch, and jiggle the key about while you're trying to start it. Worked for me until I got a new one... Alternately, find the earth in the connector block that attaches to the ignition switch and manually earth it while trying to start the bike.
(FWIW, the sidestand cutout, clutch switch and kill switch all stop the starter from turning, so you can fairly reasonably discount them as being the problem and no, I don't think they're supposed to go closed circuit when the stand's up) ____________________ Current garage: VFR800 FI-W | RD500LC YPVS | SV650 K2 | MZ TS250/1 | MZ ETZ251 | BSA WDB40
Previous notables: H100 S2 | CB250NA/B | CB250T | GT250X7 | Z650 B1 | SR650
Still owned, but long gone: RD250LC | CB750F2 SOHC | C50 |
| benvanwell |
| StealthDJ |
 Posted: 11:53 - 07 May 2008 Post subject: |
No problem.
Haynes is your friend (for a change). I'm willing to bet it'll show a dedicated earth line direct from the CDI to the ignition. It'll also show the ignition pickup inputs to the CDI, so you can bung a multimeter on them too and spin the starter. You won't get an accurate voltage, but you'll get an indication of whether there even is a signal. You can do the same with the low tension outputs from the CDI to the coils.
Oh and without wanting to be patronising, you have checked all your fuses, right?  ____________________ Current garage: VFR800 FI-W | RD500LC YPVS | SV650 K2 | MZ TS250/1 | MZ ETZ251 | BSA WDB40
There is a gap of 6 years, 233 days between these two posts... |
| snodgrba |
 snodgrba L Plate Warrior
The last post was made 11 years, 292 days ago. Instead of replying here, would creating a new thread be more useful? |
