Fuel Consumption Problems
Rowey
PostPosted: 16:06 - 04 May 2008    Post subject: Fuel Consumption Problems Reply with quote
Hi, I recently got my old CB250n Superdream purring again, after some new plugs, and a generally thorough servicing, including getting the valves adjusted and carbs balanced, I've noticed it's using a lot of fuel. I topped the tank up, from empty, with £10 of petrol and it got me, according to the clocks, only about 40miles before I was on reserve. I put the fuel tap off whenever I set it down, to make sure it's not dumping fuel, and as far as I'm aware I'm not having any lean, rich mixture problems.
I worked it out to be about 18mpg, which is way under it's quoted 50-60mpg. I was thinking check the air filter, air box and air seals for any leaks. Anything after or before that I should check.
Any help is appreciated
ZX6R C6F.
2006 _p1
PostPosted: 16:36 - 04 May 2008    Post subject: Reply with quote
is there any sign of a fuel leak?
MaybeGuy
PostPosted: 17:08 - 04 May 2008    Post subject: Reply with quote
my bets are on the float bowls leaking.
i remember working on my 250 and my 400 superdreams, they were an absolute bastard! i never managed to stop the leaks, just slow them to maybe a drip a minute.
the best test i found was to lay a washing up glove underneath either the runoff line or the carbs (if you dont have the line)
the petrol reacts with the rubber in the gloves, and it makes a big obvious blister appear.
Rowey
PostPosted: 22:26 - 04 May 2008    Post subject: Reply with quote
There was a problem with the carbs leaking through the bowl overflow, but I had the floats adjusted and it's stopped doing it now.
I always turn the fuel off when the bike is parked up, so the only time it could be leaking fuel would be when I'm riding it. Thanks for the tip Matt, I'll try that, maybe tie a glove around the two overflow pipes to "catch" any fuel that may come out when riding.
ZX6R C6F.
Odie
PostPosted: 07:39 - 05 May 2008    Post subject: Reply with quote
With the price of fuel going ever higher, how easy is it to open your fuel cap?
Fuel thefts have already started near me! Evil or Very Mad
panrider_uk
PostPosted: 09:46 - 06 May 2008    Post subject: Reply with quote
Mine has a lockable cover. Don't most bikes these days?
I'd not thought about fuel theft tbh but there's no anti-siphon on a bike is there?
Mark
Odie
PostPosted: 11:52 - 06 May 2008    Post subject: Reply with quote
Mark
ever heard of fuel pipe?
Its visable on a bike, it goes between the tank and the carbs, undo it, turn the tap to on and bobs your uncle fuel!
Rowey
PostPosted: 21:51 - 06 May 2008    Post subject: Reply with quote
It's definitely not fuel theft, I would presume I'd lose a lot more than I have.
This week, I've managed to get about 30mpg, which is better, but still a little way off the 50-60mpg I should be getting. I've checked the overflow pipes after riding, and can't feel any fuel, but I'll try tying a balloon round them after the next fill up.
I'm gonna check the plugs out asap, see what colour they are, and whether the engine is running fine.
ZX6R C6F.
smeg918
PostPosted: 22:08 - 06 May 2008    Post subject: Reply with quote
If your plugs are black and sooty that's where the fuel is going, is the choke definitely going off. ?
The last post was made 18 years, 128 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 60.07 Kb
