NC35 start ok but cuts out when engages gear!!!
my996
PostPosted: 22:21 - 04 May 2008    Post subject: NC35 start ok but cuts out when engages gear!!! Reply with quote
Hi all...
Hope you can help me on this. Have just got hold of an NC35 to use for trackdays. It starts fine but when you engage a gear, it cuts out. I am assuming it is the sidestand cutout, except there isn't a stand on it (taken off by previous owner).
Anyone know enough about these bikes as to where the wiring would go, so I can trace it back???
Thanks in advance for any help.
Les
damz
PostPosted: 01:43 - 05 May 2008    Post subject: Reply with quote
it doesnt have a stand? Shocked
Current Bikes RVF400 - 94
Cars: RX7 FD, Eunos Roadster
Rit
PostPosted: 02:14 - 05 May 2008    Post subject: Reply with quote
Does it jump forward when you engage gear? could be clutch adjustment.
You watching this rubbish?
Naaaa, switch over, Neighbours is on in a minute!
www.ritzbitz.co.uk
dr_adams
PostPosted: 04:37 - 05 May 2008    Post subject: Reply with quote
no stand as trackbike i assume... does it stall even with clutch in? The wiring is normally where the stand would be, depends on how far it has been taken back but normally a push switch where the side stand would be....
my996
PostPosted: 08:59 - 05 May 2008    Post subject: Reply with quote
Correct, its a trackbike, and yes before clutch is released. Have looked for the wire at stand end but cannot find anything. Must have been cut back but not a clue how far Sad
Any suggestions (I don't think previous owner will know)...
Thanks again!!!
dr_adams
PostPosted: 04:32 - 06 May 2008    Post subject: Reply with quote
i have looked everywhere for a manual to find the wiring diagram but alas i can't find it.... i would prob suggest www.400greybike.co.uk as they would be able to answer instantly, the parts manual shows a two wire connection just behind the stand :S so might be worth having a look for this as its got to be connected or you wouldn't be having the problems! sometimes racers hide them under seats as a cut out:S
dr_adams
PostPosted: 04:34 - 06 May 2008    Post subject: Reply with quote
https://www.motoinfo.yoyo.pl/Honda/Honda%20RVF400R.jpg
go there and all is sorted, not brill quality but in the very bottom left is the thing your looking for and you can see where it connects and take it from there:)
my996
PostPosted: 07:09 - 06 May 2008    Post subject: Reply with quote
many thanks, will have a go dr_a...
my996
PostPosted: 15:25 - 10 May 2008    Post subject: Reply with quote
ok, have found the wires in the loom. There are 3 (yellow/black green/white green) which ones do I connect together???
Again thanks in advance...
my996
PostPosted: 18:20 - 11 May 2008    Post subject: Reply with quote
Hi there...
Have figured it out, connect the green with the green/ white trace... job done Smile
binge
Emo Kiddy
PostPosted: 21:38 - 12 May 2008    Post subject: Reply with quote
Short out the two outside wires. Thumbs Up
The last post was made 17 years, 225 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 65.13 Kb
