LOSING NUTS
stirlinggaz
PostPosted: 18:50 - 05 May 2008    Post subject: LOSING NUTS Reply with quote
Hi all,
my exhaust is mounted by way of a simple nut & bolt.
problem is, i keep loosing them!
no matter how tight i put the nut,
seems to loosen off within days.
without resorting to spending money, ie on threadtite.
is there any way to stop it loosening off?
ie spring washers etc?
cheers,
GAZ
stu_m
PostPosted: 18:53 - 05 May 2008    Post subject: Reply with quote
spring washer and a nyloc nut
or threadlock Smile
Stu
Damon
PostPosted: 19:24 - 05 May 2008    Post subject: Reply with quote
get some threadlock on there. Problem solved
Kal
PostPosted: 19:41 - 05 May 2008    Post subject: Reply with quote
Had this problem on the Trike because of it's massive vibrations, I've had some success having a hole being drilled through the bolt and banging a splitpin through it.
Kal...
MattEMulsion
PostPosted: 21:28 - 05 May 2008    Post subject: Reply with quote
Nyloc nuts will be no good if it is on part of the exhaust system that gets quite hot. It'll just melt the nyloc out of it. I'm not 100% sure threadlock with withstand any heat either.
My solution would be to either use spring washers or failing that put an extra nut on top on the normal one and lock the two nuts together. That should stop it from vibrating undone. Thumbs Up
Yamaha YZF-R6
alains
PostPosted: 22:57 - 05 May 2008    Post subject: Reply with quote
i think you're right if the thread is long enough , otherwise my solution is one punch between bolt and nut after tightening
Kal
PostPosted: 00:00 - 06 May 2008    Post subject: Reply with quote
One punch?
Kal...
alains
PostPosted: 09:16 - 06 May 2008    Post subject: Reply with quote
yes , something simple
Kal
PostPosted: 09:35 - 06 May 2008    Post subject: Reply with quote
Isn't that going to prevent you from removing the bolt if you need to?
Kal...
alains
PostPosted: 10:43 - 06 May 2008    Post subject: Reply with quote
no , if you undo the nut you will have a hard point but not for long and you are not undoing the nuts all the time . i use to make 2 at 180° even 4 at 90° when i need a really hard stoppage . when you take the nut off the thread is very little damaged and repair itself
stirlinggaz
PostPosted: 18:04 - 06 May 2008    Post subject: Reply with quote
hi,
think the bolt is too long,
will try the two nuts tightened together,
dunno why i didnt think of that & also hitting it with a nail punch,
cheers,
GAZ
ZRX61
Victor Meldrew
PostPosted: 07:53 - 07 May 2008    Post subject: Reply with quote
It's called "staking" Wink
alains
PostPosted: 08:29 - 07 May 2008    Post subject: Reply with quote
thanks my friend
ZRX61
Victor Meldrew
PostPosted: 00:23 - 09 May 2008    Post subject: Reply with quote
.. & the usual method is 3, at 120deg intervals.
The last post was made 18 years, 176 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 77.77 Kb
