| Silky |
 Silky Nova Slayer
 Posted: 19:11 - 04 May 2008 Post subject: Scary Noises! |
Hi guys and gals,
My GPZ500 has been making some curious noises lately...
At idle its fine, nothing out of the ordinary, but once on the move there seems to be a random knocking sound. As if there is something flying about inside the engine. Gets a little louder at speed.
Sounds like its near the front low down, maybe in the sump. Surely I should have been launched off the thing by now...?
Happens with the clutch in or out regardless. Have also ridden it without the bellypan on and have checked for external problems.
Any help is appreciated. Thanks! ____________________ Have ya ever drunk Baileys from a shoe? IM OLD GREGG!!! |
| Ariel Badger |
 Ariel Badger Super Spammer
| bladerunner |
 Posted: 22:29 - 04 May 2008 Post subject: |
If you have a mobile then take a vid of it and upload it to you tube and post the link here as it's always a lot easier to diagnose if we can hear it!! Other points ...does it get better/worse when hot and does it do it more under load or is it always the same
HTH
Blade ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 23:13 - 04 May 2008 Post subject: |
am i the only one who thinks it could be big end bearings??
i dont care if i scare people  ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| smeg918 |
 smeg918 Derestricted Danger
| 2006 _p1 |
 2006 _p1 Crazy Courier
| Silky |
 Silky Nova Slayer
 Posted: 11:08 - 05 May 2008 Post subject: |
Ariel, it doesnt make any noise when still even if revved. Seems to be linked to speed/movement of the bike.
Definately isnt the big ends, i know what that sounds like.
Sounds really low down, so i dont think its the cam chain or tensioner.
Cant really take a vid as i'll have to hang off the bike lol! Doubt that would help anyway.
Is a very randomly occuring sound, like a tiny bit of metal shoved in a washing machine.  ____________________ Have ya ever drunk Baileys from a shoe? IM OLD GREGG!!! |
| Silky |
 Silky Nova Slayer
| smeg918 |
| Silky |
 Silky Nova Slayer
| element |
 element World Chat Champion
 Posted: 12:44 - 07 May 2008 Post subject: |
the bike will run hot on a short ride especially if your not at any pace to keep the engine cool. Im assuming that your bike doesnt have a fan on the rad. If you have a temp gauge (my mate has the same bike but i cant remember) then just keep an eye on it. make sure its not going in the red. Might be worth checking your coolant level. The engine temps will rise when there is not enough coolant in the system!
also on my bike (i have a dt, completely different but still its the same on my dads 4t) you cant see any oil in the window while the engine is running. switch it off and watch level in the window slowly rise  ____________________ 04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME... |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
| Silky |
 Silky Nova Slayer
 Posted: 14:09 - 07 May 2008 Post subject: |
Checked my coolant and it was a little low, so I've topped it up.
Hopefully that'll have it sorted.
Thanks for the advice guys!
| element |
 Posted: 18:52 - 07 May 2008 Post subject: |
What year/reg of GPZ500 is it?
What makes you think it is getting very hot? Does it feel hot or is the temperature guage telling you it's hot? How far up is the guage going? Is the fan coming on? Does the fan ever come on?
For future reference, if it had stopped circulating oil, it would be a dead engine very quickly indeed. The red oil warning light on a GPZ500 is attached to a pressure switch. It should come on when you switch on the ignition and go off the instant you fire up the engine.
If that light goes straight off on startup, there is adequate oil pressure. If it ever comes on when riding pull in the clutch and kill the engine immediately until you've found out what the problem is (usually an electrical malfunction when it comes down to it). If it's come on due to low oil pressure, you are damaging your engine with every second it is running.
With regard to the noise:
Check to see if there is a splitlink in your chain. If there is, get it changed or at a minimum give every single link a thorough inspection (including making sure it moves about as it should). I've had three chains fail at the splitlink on me on GPZ500s and each time it was preceeded by a knocking/clattering noise.
Also check your rear sprocket isn't all worn out and hooked over. If you find nothing, check the front sprocket, it is held on by a thrust washer and two short bolts. The bolts sometimes start to unscrew themselves if they weren't put in tightly enough. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 18 years, 139 days ago. Instead of replying here, would creating a new thread be more useful? |
