anything to worry about?
DevilDex666
PostPosted: 14:41 - 07 May 2008    Post subject: anything to worry about? Reply with quote
Hi all,
A guy I work with has asked me to post this as he currently has no internet access. He owns a Daifer Scooter and has had it nearly a year. The issue he has is that when he pushes the scooter backwards, to get out of a parking spot for example, the back end feels as though its stiffening up and becomes quite hard to push. Is this normal? He says it has not always been like this and can occasionally be pushed back fine. I told himm to take it for a service, what do you guys think?
"But I being poor, have only my dreams, I spread my dreams under your feet, tread softly because you tread on my dreams." ("He Wishes for the Cloths of Heaven" - W.B. Yeats)
Thom
PostPosted: 14:54 - 07 May 2008    Post subject: Reply with quote
brake locking on/binding?
DevilDex666
PostPosted: 15:00 - 07 May 2008    Post subject: Reply with quote
hmmm I did think that but would it not do the same going forward? it's fine going forward, only in reverse it has the issue.
NSR Mick
PostPosted: 15:52 - 07 May 2008    Post subject: Reply with quote
Rollers / centrifugal Clutch / Other automatic scoot device may be sticking.
map
Mr Calendar
PostPosted: 16:05 - 07 May 2008    Post subject: Reply with quote
Another vote for a brake issue. It'll be drum brake on the back and they obviously wear a certain way. It's uneven wear across the pad accounting for the way they work. Pushing the bike backwards may cause them to be a bit upset and lock on.
I'd check the brakes first, although on most scooters not straightforward as you may need to loosen/remove the exhaust to get at the thing.
FWIW an old trick for increasing the life of the drum brake pads is just to fit them in the other way round to even up the wear.
HTH Thumbs Up
DevilDex666
PostPosted: 17:25 - 08 May 2008    Post subject: Reply with quote
ok thanks guys, I will let him know what you guys think. He may just decide to get a service done as its approaching its first 1000 miles. Cheers for all your input.
The last post was made 18 years, 169 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 48.36 Kb
