Spark, Compression, Fuel. Wont Start :@
craigspeedfig...
PostPosted: 13:50 - 08 May 2008    Post subject: Spark, Compression, Fuel. Wont Start :@ Reply with quote
Like It Says There's a spark & i got a fella to have a look he said there's compression & fuel is getting through.
He Said Piston Rings Have Gone Any Body Agree Or Should i get anouther Fella to have a Look?
StealthDJ
PostPosted: 14:01 - 08 May 2008    Post subject: Reply with quote
If there's compression, the piston rings haven't completely gone.
I'd get a second opinion, if I were you.
Current garage: VFR800 FI-W | RD500LC YPVS | SV650 K2 | MZ TS250/1 | MZ ETZ251 | BSA WDB40
Previous notables: H100 S2 | CB250NA/B | CB250T | GT250X7 | Z650 B1 | SR650
Still owned, but long gone: RD250LC | CB750F2 SOHC | C50
garyd
PostPosted: 14:41 - 08 May 2008    Post subject: Reply with quote
The blokes a knob Thumbs Down
CRF230 all you need
PostPosted: 14:53 - 08 May 2008    Post subject: Reply with quote
Sure if the rings were gone then it wouldn't have compression?
Welshd1k
PostPosted: 18:24 - 08 May 2008    Post subject: Reply with quote
try new plugs they might spark out but might not inside under compression (what was wrong with my zxr Wink )
TUG
PostPosted: 19:00 - 08 May 2008    Post subject: Reply with quote
If its not your plug, i assume this is a speedfight thats not starting?
Try a new plug if this ones a bit old, If that fails and your sure its got the things you listed then i'd give it a good once over, check everything is connected right like the petrol vacuum pipes fot the carb from the tank.
Haz ER-5, innit!
craigspeedfig...
PostPosted: 22:12 - 08 May 2008    Post subject: ermm Reply with quote
Well The Plug Is Fairly New.....Should I Just Take It To Bits & see if can find owt tht dunt look right?? Can Anyone Give Me A Clue Of What Might Look Dodgy?? My Dad Can do it, But he's On holiday & i want rid of it ASAP! Thanks For The Advice (Y)
TUG
PostPosted: 23:43 - 08 May 2008    Post subject: Reply with quote
Dont touch it, let you dad take a look, i wouldnt recomend takin it apart if you dont know how they work and what to look for.
Haz ER-5, innit!
The last post was made 18 years, 177 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.83 - MySQL Queries: 13 - Page Size: 53.24 Kb
