Mixing Bridgestone tyres?
neatbik
PostPosted: 20:39 - 11 May 2008    Post subject: Mixing Bridgestone tyres? Reply with quote
Hi, i have a nearly new bt014 on the front, and a squared off worn out bt014 on the rear. The rear has lasted about 3000 miles, but i want the next one to last a bit longer really. Would i be ok to replace the rear with an 020 or 021?
Im thinking i will be, but it never hurts to ask
Cheers Thumbs Up
The Tot
PostPosted: 20:45 - 11 May 2008    Post subject: Reply with quote
What bike do you have? i take it's a triumph speed triple/four/street triple?
I've got a BT014 front/020 rear combo on my ZX6R and I, for the life of me cannot get any feeling of confidence from the rear - different shaped profiles, front is a super sticky sports tyre, the rear is a hard as wood sports touring tyre. I've had 3000 miles out of it so far and the rear is squaring off, the front is OK, but the mismatched profiles make me ride slower since i cant feel confident dropping it in - the front's eager, but the rear is sluggish.
They're good for commuting and the odd weekend blast, but i have to be very careful when pinning the throttle on the corner - i've had her wiggle the front a few times as the back end stepped out.
That combo is good for say 6000 miles?
FWR tyres in london will do you them for 170 installed, which is what they recommended me.
Never argue with autism
neatbik
PostPosted: 20:58 - 11 May 2008    Post subject: Reply with quote
Its a Speed Four mate Thumbs Up
I was wondering about the possibility of different profiles to be honest... I like the grippiness of the '014 but i cant afford to keep replacing it as often as it needs, plus a lot of my mileage is boring straight line commuting. I guess ideally i should get a matched pair of 021's, but ive just replaced the front tyre and i cant afford to change it so soon.
petemell
PostPosted: 21:03 - 11 May 2008    Post subject: Reply with quote
I don't think you can mix crossplys with radials, but you can mix different manufacturers alright. Not sure though.
The Tot
PostPosted: 21:38 - 11 May 2008    Post subject: Reply with quote
Well if you want to put it how i put it
I basically said to the FWR tyre guy
"Mate, i'm got some dunnies on my bike - qualifiers, they're pretty stable and confidence inspiring, but they don't last as long as i want. I need a compromise of good front end feel with longevity for commutes. What can you recommend me?"
His reply was
"we've fitted customers with 014/020 combos, we can also recommend you pirelli diablo stradas and pilot road 2's but your budget is about 200 quid fitted - we'll fit a bridgestone combo for 175"
I weren't gonna argue with the dude at FWR tyres. It was OK for the first few miles, it really did feel agile (it was last summer) and i was happy with it, but since the crash, riding through winter and 60 mile daily commutes at 90mph, it's flattened the profiles and squared them off - not my fault really. THAT's what causes the lack of confidence. I am pretty sure if i was screwed in the head, it's just a psychological thing. It didn't work for me, but i don't think it's any fault with the tyre or the bike.
Pete, FYI - you CAN mix crossplys with radials, although NOT recommended. I believe you can have a rear crossply with a front radial, but NOT have a front crossply and rear radial (MOT failure for the reason explained to me by my mechanic)- it's got something to do with how the tyres are constructed and how much heat and thus grip is generated, with crossplies being a much older tyre technology. Crossplies are effectively a heavier tyre because of the way that they are constructed, and having one at the front will produce an larger moment of inertia, greater gyroscopic mass and would make the bike harder to steer - reasonably OK if your bike is fitted with crossplies as standard, but not recommended on supersports. Also, Mick Doohan has long retired Wink Razz , make way for pedrosa and lorenzo!
To be honest beatnick, you can't really go wrong with the pair you've suggested, they're perfectly good - I believe G's had that combo and i KNOW wave 2k has had that combo on his cbr600rr, i've seen plenty of sportsbikes having a similar arrangement, so it's a good compromise, but i'd give your tyre man a brief of what you want. I think cos technology has moved on and if you have a healthier budget, they might whisper into your ear "michelin pilot road 2's" - these will be my next tyres
neatbik
PostPosted: 21:58 - 11 May 2008    Post subject: Reply with quote
Cheers mate Thumbs Up
If i had the money i think i'd go for a pair of pilot road 2's, or possibly Conti road attacks, but im getting married in sept, im doing a 'stag' trackday in july at anglesey, the bike will need a service before that plus i need to buy a decent jacket for the trackday.
All that, along with normal day to living (incl. 3 kids) is taking its toll on the wallet! Shocked Laughing
PostPosted: 22:56 - 11 May 2008    Post subject: Reply with quote
Front BT010 with a rear BT020 was a pretty common combination.
You can have a front cross ply and a rear radial legally, but not a front radial and a rear cross ply.
Old VF1000R from the mid 1980s had a front cross ply and rear radial as standard fitment.
Kris
PostPosted: 12:51 - 12 May 2008    Post subject: Reply with quote
I have a BT-014 front with a BT-021 rear and have no problems on the SV1000 Thumbs Up
www.prisonplanet.com
The Tot
PostPosted: 16:04 - 12 May 2008    Post subject: Reply with quote
I stand corrected Keith Thumbs Up Cheers, i knew it was something along the lines of that.
Now that the road temperature is getting up, my tyres are coming into good use now. I've already noticed the gradual deterioration of chicken strips which can only suggest that i'm getting more confident on it.
neatbik
PostPosted: 18:09 - 12 May 2008    Post subject: Reply with quote
Kris, what kind of mileage are you getting out of the BT021? And is it liable to square off easily?
Cheers Thumbs Up
Kris
PostPosted: 21:05 - 12 May 2008    Post subject: Reply with quote
Cheers Thumbs Up
Well I've had it for 1000 miles now on the SV, so can't comment on longetivity yet....although I had them on my Bandit 600 and it lasted 6000 miles easy, although was fairly squared off by then. I'm 100% certain that they have not squared off prematurely, no mean feat considering most of my commute is A-road and M-way. Thumbs Up
I find them very similar in grip and life to the old BT45's I had on my previous bikes, which seems the perfect balance to me. Lots of grip, pretty good wear rate. I do think however that the SV may eat them slightly faster... Twisted Evil Rolling Eyes
The Tot
PostPosted: 10:31 - 13 May 2008    Post subject: Reply with quote
Beatnick - the 020's i've had have been going for 3500 miles and show signs of squaring off. The front is OK, still plenty of meat left, the rear looks like it hasn't worn down at all, but the profile does show signs of squaring off, considering 2500 miles of which have beencommutes in a straight line (literally) for 60 miles at a time averaging 70mph! By which point my regular fitments of dunlop qualifiers would be as flat as a pancake. If you mix your riding, then it won't be as bad.
The last post was made 18 years, 148 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 78.52 Kb
