| matty_d89 |
 matty_d89 L Plate Warrior
| TUG |
 TUG World Chat Champion
| virus |
 virus World Chat Champion
 Posted: 19:12 - 11 May 2008 Post subject: |
running lean, they tend to rev a little bit higher if they are lean, and when you let go of the throttle (which drops the needle back into the main jet, restricting fuel flow) it gets too lean to keep running.
be thankful its stalling, if it didn't it would blow a hole in the piston.
do a plug check, see what colour it is.
Cheers
John ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| Paddy Blake |
| CaNsA |
 CaNsA Super Spammer
| matty_d89 |
| virus |
 Posted: 18:08 - 12 May 2008 Post subject: |
in that case I can only put it down to the pilot system, check the pilot jet isn't blocked. turn the pilot air screw (on the bottom of the carb, right at the front) in counting turns until it stops, then turn it back out one and three quarters.
Cheers
| matty_d89 |
 Posted: 18:12 - 12 May 2008 Post subject: |
ah rite that somthing different altogether! will get the haynes out i think, the idle is quite erractic at times so could be that. its a 1993 on k plate |
| palmeale2 |
 palmeale2 Derestricted Danger
 Posted: 00:24 - 13 May 2008 Post subject: |
I had a similar problem with my 1996 cg when i first bought it, as it would just cut out all the time. Are you sure its not the choke? It took me and my friend ages to figure out if the choke was on or not. They discuss the choke in this thread here: https://www.bikechatforums.com/viewtopic.php?t=48428
Alex |
| Cigaro |
 Cigaro World Chat Champion
| matty_d89 |
 Posted: 12:46 - 13 May 2008 Post subject: |
im hopefully going to take it for a long ride wed or thurs as have exams atm. no choke is not on full its fully down checked a few times. its supposidly had a replacement carb but will check that.
as for the pilot system i'll see if it still playin up after a long ride an take it back to the garage that sold me the thing before i start playing about with it. i may then be liable if i mess it up even more cheers though i'll let u kno how it goes |
The last post was made 17 years, 225 days ago. Instead of replying here, would creating a new thread be more useful? |
