| Noxious89123 |
 Noxious89123 World Chat Champion
 Posted: 21:56 - 11 May 2008 Post subject: Removing restrictors on a CBR600f-y |
Is it a big job, or do-able by a novice?
I haven't done any major mechanic typ stuff myself.. biggest thing i've done really is to adjust my chain tension
I've no worries about taking off the air duct covers and getting the tank levered up, that looks rather simple (haynes ftw).
It's fiddling with the carbs / airbox that has me a bit uneasy.
Any advice? ____________________
'06 Honda CBR125RW-6 ~ '00 Honda CBR600F-Y ~ '07 Honda CBR600RR-7 ~ Bikeless
'53 Ford Ka 1.3 ~ '03 Vauxhall Astra SRi 1.8 ~ '52 Vauxhall Astra SRi 2.2 ~ '53 Vauxhall Astra GSi |
| Pie-Roe |
 Pie-Roe World Chat Champion
 Posted: 06:59 - 12 May 2008 Post subject: |
If it's a carbed one, and just washers, no problem.
Tank off, Disconnect associated gubbins which are connected to each other, (air box lines/bits of seemingly unimportant rubber which you later will realise ARE important)
Airbox off(if it is under the tank and above the carb)
Take the entire carb assembly off from the intake. Washers sit inthe rubbers between the whole carbs and the head (I think)
This was how it worked for a zxr400 I helped do the other day, can't be that dissimilar
If you google how to balance carbs on your bike model, you can probably find a step by step guide of how to strip down to your carbs, then its a simple case of carbs off, rip those washers out, then put back on. You can do it from a haynes, just if you do, get some postit notes, go through and find exactly what you want. It's annoying fiddling with oily fingertips trying to find the page when it says 'now refer to chapter 9'
Pyro ____________________ Previous: GSF600, FZR600 x2, ZXR750, XT600 Tenere, CB125, CZ125, ETZ 250, ER5, CCM R30, DRZ400, RF600x4, RF900x2, GS500, VTR1000F, 640 SMC, CB250 NIGHTHAWK, GT550x3, GPX750 TE610, CB500, X11x2, SV650, ZING 125, TL1000R,CB250 Superdream, CBR1100XX |
| Egret |
 Egret Nova Slayer
| Noxious89123 |
 Posted: 19:33 - 12 May 2008 Post subject: |
Just a bit more info for those interested, my restriction crt. says this;
Device: Inlet blade + Carb Caps
Device code: 02-PC35-K25
Device details and dimensions;
Outer diameter = 44mm
Inner Diameter 1 = 11.5mm
Inner Diameter 2 = N/A
Hieght (thats how it's spelled ) = 22mm
Max power = 33bhp @8800rpm
Max Speed = 96mph / 154kmh ____________________
| Noxious89123 |
 Posted: 21:48 - 04 Jul 2008 Post subject: |
Inlet blades! EDIT: Ignore this, i was wrong. I'm a noob.
https://img393.imageshack.us/img393/564/restrictorsjc9.jpg
I thought i could get them out by removing the top black part, and removing the air funnels. Turns out it's not that easy, it's slightly further into the carb than that
Might have to take the "top" (front?) of the carbs off, which seems alot bigger job!
Dunno if there are washers between the carbs and heads, will find out if i can work out how to get the carbs off! Seems to be alot that will need disconnecting, ehich i'm trying to avoid; Was hoping i'd be able to just lift them up an remove the washers with out any major dissassembly of the carbs, or removing all the fuel lines, air hoses and coolant hoses.
EDIT:
The "inlet blades" seem to be just before the butterflies. I can't remove them just by removing the air funnels, they're just inside the actual body of the carb.
Do i need to remove the carb top, and the piston/diaphragm to get these out? More importantly, can i partly dismantl the carbs without having to disconnect fuel lines / coolant hoses etc?
Hope for a fast reply! Want to get this sorted in the morning. ____________________
| Timmeh |
 Timmeh World Chat Champion
| Noxious89123 |
 Posted: 22:22 - 04 Jul 2008 Post subject: |
| Timmeh wrote: | You shouldn't have to remove the stacks, all you're trying to get to is the inlet manifold locking rings, which sit directly between the bottom of the engine and the carbs.
Undo all eight of them using an ELS (Excessively Long Screwdriver) and rock the carb bank back and forth until they pop off. You might have to remove the choke cable and bracket at the front of the carbs, but there is no need to disassemble the throttle cables which run up through the centre of the carb bank.
If it's anything like my F3 then you'll also need to remove the centre fuel feed t-piece and the carb heater pipes at the thermionic valve end which is bolted to the engine next to the starter motor. If you have to do this, drain the coolant first.
Be careful with the rings, they mash real easy, if you've rounded any of the screws off getting them out it's always a good idea to buy replacement ones from honda, they're about 2 quid each. Even tiny air leaks will trash your fuelling.
I tend to replace them as an entire set if I've rebuilt engines or carbs if they've been in situ for a few years. |
Your bike is a steelie, correct? The differences between your bike an mine are ALOT. Totally different frame and engine afaik.
The throttle cables are on the RH side of the carbs. (So they're attached to #4. I just want to be able to lift the carbs up, but there's no room for movement with the throttle cables that go to the front of th bike, and not much with the fuel and coolant lines at the back.
The choke is easy enough to detach. Thing the throttle cables will hav to be detached too, just to make life easier.
I don't have an ELS, will have to go pick one up in the 'morrow, because its going to be a PITA otherwise. ____________________
| Timmeh |
 Posted: 22:27 - 04 Jul 2008 Post subject: |
fair do's.
 ____________________ GSXR400 x2 | '94 RVF400 | '93 TZR125 4DL (again)
20:48:18 Temeluchus: comp you hunk of smouldering homos3x you |
| Noxious89123 |
 Posted: 22:39 - 04 Jul 2008 Post subject: |
I was advised by the gf's dad to use lots of vaseline on the inlet rubbers, to help get them back on the heads.
Wouldn't this then get drawn into the engine and do funny things?
I'm out of my depth a bit here
Might just do the CCT and put the rest back together and get a mechanicly minded friend to help me do it.
Atleast now i know how to get the tank and airbox off  ____________________
| Noxious89123 |
| Noxious89123 |
 Posted: 11:22 - 05 Jul 2008 Post subject: |
Got the carbs off the engine, but cannot for the life of me get the rubbers off of the carbs, to remove the washers.
Put them back on now, and am just going to do my CCT, and do the derestriction at a later date  ____________________
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 14:56 - 05 Jul 2008 Post subject: |
this has been quite fun to read
usually, the inlet manifold rubbers stay on the engine, and the rubbers are released from the carbs.
you have got the carbs off the EXTREME hard way. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Noxious89123 |
| Noxious89123 |
| MaybeGuy |
 Posted: 17:27 - 12 Jul 2008 Post subject: |
| Noxious89123 |
 Posted: 19:00 - 12 Jul 2008 Post subject: |
Won't be selling them, might need to put them back in at some point.
Will go measure them now... Wouldn't be hard to make your own tbh.
1mm thick steel, 42mm OD, 7mm ID, 3mm ID for the pilot hole.
| Blackwolf |
 Blackwolf Burgerfist
 Posted: 17:26 - 15 Jul 2008 Post subject: |
Haha, this may come in use
So now moves like shit of a shovel now eh?
what are the inlet blades?
and where are the blue spots on the CCT as mine makes a racket too! am properly going to get a manual CCT ____________________ Current: Ducati Multistrada 1200s |
| MaybeGuy |
 Posted: 18:19 - 15 Jul 2008 Post subject: |
in future, make sure you remove the rubber manifolds.
you can literally lift out the restrictors then, rather than prising them out with tools that will potentially damage the rubbers. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| damz |
 damz World Chat Champion
 Posted: 18:23 - 15 Jul 2008 Post subject: |
i had to do the same thing when removing the restrictors from my rvf the other day, of course we spent ages looking in the carbs for the restrictors and gave up for the day only to find out that the washers were below the carbs and were in plain sight the whole time  ____________________ Current Bikes RVF400 - 94
Cars: RX7 FD, Eunos Roadster
Former Bikes: FZR 250R 89, ZX7R 98 |
| Noxious89123 |
| MaybeGuy |
 Posted: 20:50 - 15 Jul 2008 Post subject: |
they are held in by jubilee clip type things. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Noxious89123 |
 Posted: 22:04 - 15 Jul 2008 Post subject: |
Even if you fully loosen the clamps, or totally remove them, the rubbers are an incredibly tight fit to the carbs. ____________________
| Timmeh |
| damz |
| Noxious89123 |
The last post was made 18 years, 30 days ago. Instead of replying here, would creating a new thread be more useful? |
