Motorcycle ABS and MOT
James
PostPosted: 14:38 - 12 May 2008    Post subject: Motorcycle ABS and MOT Reply with quote
Afternoon all, just a quick question regarding MOT test. Basically I've got a bike that has ABS but the light is constantly on meaning there is a fault. I have taken out the bulb so no more abs light but is this an mot fail?
The brakes work ace, all the pads are excellent as are the discs...
Thanks in advance for any help
Like shit off a stick
PostPosted: 14:48 - 12 May 2008    Post subject: Reply with quote
Would be a fail for a car, and would expect it to be a fail for a bike although it is not listed in the (out of date) manuals online.
Entirely possible that riding the bike with the ABS not working would be regarded as an offence of "Using a vehicle with defective brakes" - CU10, upto £2500 fine and 3 points.
map
Mr Calendar
PostPosted: 14:59 - 12 May 2008    Post subject: Reply with quote
Quick question - are you sure it's the ABS. From what I remember BMW use the ABS warning light to signal other fault conditions. Maybe worth checking.
HTH Thumbs Up
Finglonga
PostPosted: 17:49 - 12 May 2008    Post subject: Reply with quote
HTH Thumbs Up
Indeed, on mine it also lets you know if the brake/tail light bulb has blown.
Andy Sez....
F.Y.Y.F.F.
James
PostPosted: 21:43 - 12 May 2008    Post subject: Reply with quote
Cheers for the responses its definitely a problem with the ABS system. Any MOT testers can shed light on this, is it down to their discretion seen as the test criteria doesn't mention it?
PostPosted: 22:00 - 12 May 2008    Post subject: Reply with quote
The manuals online are not up to date unfortunatly.
Even if the bike passes there are legal issues (can think of a case from 20 years ago where someone was prosecuted for faulty brakes because a traffic light camera snapped them going through with locked wheels on a car with standard fit ABS).
PostPosted: 22:33 - 12 May 2008    Post subject: Reply with quote
Seems a bit crazy to me that it could fail for something that is not essential.
If the brakes work perfectly fine I can't see what the problem is. It'd just be like any other bike that didn't have ABS brakes Confused
PostPosted: 22:42 - 12 May 2008    Post subject: Reply with quote
Quite possibly they don't. The warning light could be there to say the system is leaking fluid internally when under pressure.
And legally they are faulty.
PostPosted: 22:59 - 12 May 2008    Post subject: Reply with quote
A bike without a warning light could have that problem but if it passes the braking test on the M.O.T it would pass the M.O.T all together right?
Tiff
PostPosted: 23:35 - 12 May 2008    Post subject: Reply with quote
ABS isn't part of the bike test yet. You should advise the presenter of a fault in the ABS,but as long as the brakes meet the required standard like a non-ABS model,then no problem.
1996 Kawasaki GPZ1100s,1996 VFR750,1980 BMW R80,1982 Kwak Z250B,1992 ZZR1100C,1996 BMW K1100LT,1994 Kwak ZZR600E,1993 BMW R1100RS,1992 ZZR 600D,1988 BMW K100LT,1998 Aprilia Pegaso 650,1994 Suzuki RF900,1991 Yamaha XJ600, 1988 Honda Dominator,1992 Kwak KMX125,1987 Yamaha RD50MX,1984 Honda MBX50.1984 Honda Superdream 125
PostPosted: 23:49 - 12 May 2008    Post subject: Reply with quote
Passing the MOT and being road legal are 2 different things.
Tiff
PostPosted: 23:51 - 12 May 2008    Post subject: Reply with quote
Yup- The MOT test, and the constructions and use manual are very different!
Finglonga
PostPosted: 11:18 - 13 May 2008    Post subject: Reply with quote
Also worth noting if its a BMW the ABS light wont go out if the battery doesn't have enough charge in it to start the ABS pump.
Andy Sez....
F.Y.Y.F.F.
The last post was made 17 years, 339 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 82.04 Kb
