helllllllllp
 Topic moved: from General Bike Chat to The Workshop by G (14 May 2008 - 11:05)
Fitton
PostPosted: 11:14 - 13 May 2008    Post subject: helllllllllp Reply with quote
just been getting redi to go out on my cg and it fell over Sad Sad
now it wont start, could it just be that its flooded?
also the right indicator casing has smashed now aswell Crying or Very sad
https://www.worldskillsteamuk.org/export/sites/vpt.worldskills2007.content/global/resources/images/sponsorLogo-honda-195x135.gif
Fitton
PostPosted: 11:21 - 13 May 2008    Post subject: Reply with quote
anyone Sad
sagalout
PostPosted: 11:22 - 13 May 2008    Post subject: Reply with quote
Probably flooded, also check you havent accidently knocked the killswitch when picking it up
This should be in workshop, anyway sometimes they get a bit upset after they have been on their sides so just keep trying. It'll catch eventually.
Quote Me Happy
PostPosted: 11:25 - 13 May 2008    Post subject: Reply with quote
My XR gets upset after being on it's side and floods.
Just leave it for 10 mins then go back to it, unless you have a decompression lever on the CG?
Fitton
PostPosted: 11:32 - 13 May 2008    Post subject: Reply with quote
thanks for your help
it starts again now thank god
anyone know if and where i can pick up a right indicator case/shell?
PostPosted: 11:36 - 13 May 2008    Post subject: Reply with quote
From a honda dealer, shouldn't cost a lot.
Is it the whole case or just the lense?
Fitton
PostPosted: 11:38 - 13 May 2008    Post subject: Reply with quote
just the orange lense
PostPosted: 11:43 - 13 May 2008    Post subject: Reply with quote
Get it direct from a Honda dealer.
It cost me £3 for a new one for my Aprilia RSV from a dealer, shouldn't cost you much at all.
Fitton
PostPosted: 11:44 - 13 May 2008    Post subject: Reply with quote
cheers
thanks for the help guys Thumbs Up
the grim reaper
PostPosted: 11:53 - 13 May 2008    Post subject: Reply with quote
If you flood it again, hold the throttle wide open and kick/turn it over with the kill switch off, if you can do that (some bikes won't turn at all with the killswitch off). This opens the butterflys and lets air in to evaporate the fuel more quickly.
Don't do this with the killswitch on as you risk it firing and maxxing revs on a possibly cold engine.
Grim
bipolar bear
PostPosted: 12:03 - 13 May 2008    Post subject: Reply with quote
cg doesnt have a killswitch
Suzuki SV650S K7
All Your Base Are Belong To Us
Fitton
PostPosted: 12:08 - 13 May 2008    Post subject: Reply with quote
ESB motorcycles have just told me £7.01 Shocked
the grim reaper
PostPosted: 12:15 - 13 May 2008    Post subject: Reply with quote
Grim
Wouldn't you just be filling the cylinder with more fuel? I always thought you took the plug out, kicked it over a few times and let it stand with the plug out fo a few minutes. Isn't it the plug getting wet and failing to spark that causes the problems?
No, turning it over without firing does not cause enough vacuum to raise the carb diaphragm. Only enough fuel to idle, from the idle jet, will get into the cylinder and that is a very small amount compared to the amount required to flood the engine.
Grim
Itchy
PostPosted: 12:28 - 13 May 2008    Post subject: Reply with quote
whatcha expect ESB are not very good, try arches Andy (nearby the old bolton police station near the toyota dealership) watch it though he is ill all the time so his opening hours are iffy
Rivington barn motorcycles an OK breakers
Bikers warehouse a not so good breakers
Also rock n road near the Cinema
since you are a Bolton person will you come to the Barn 1pm this Sunday?
Fitton
PostPosted: 11:48 - 14 May 2008    Post subject: Reply with quote
Yes man, I don't know the way though Embarassed
PostPosted: 12:10 - 14 May 2008    Post subject: Reply with quote
Get an AA route master, look it up on a map. Tisk, kids these days.
Itchy
PostPosted: 12:19 - 14 May 2008    Post subject: Reply with quote
Pick you up at Bolton ESB on Sunday 12ish?
Quote Me Happy
PostPosted: 12:28 - 14 May 2008    Post subject: Reply with quote
Itchy is grooming him! Paedageddon!
The last post was made 17 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.84 - MySQL Queries: 19 - Page Size: 119.02 Kb
