| cp2008 |
 cp2008 Borekit Bruiser
| cp2008 |
| Thom |
 Thom World Chat Champion
| cp2008 |
| The Artist |
 The Artist Super Spammer
| The Artist |
 Posted: 19:18 - 13 May 2008 Post subject: |
Have you lost any coolant? I'd suspect the head gasket first-off. ____________________ a.k.a 'Geri'
| iooi |
 iooi Super Spammer
 Posted: 19:23 - 13 May 2008 Post subject: |
Certainly a very weak fuel mixture by the sound of it and could also be a seized engine on the way very quick.
Could also be rings have gone on the smoke issue.
Time to strip and rebuild the engine..... ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| cp2008 |
| Rockhopper |
 Rockhopper Trackday Trickster
 Posted: 19:48 - 13 May 2008 Post subject: |
There isn't a lot to go by unfortnately
Are we talking clouds of white smoke or stinky blue smoke?
Are you losing coolant?
Is it making nasty noises, ticking, squeaking etc?
Any other symptoms?
Smoke is usually wither burning coolant or burning oil. If it's coolant, suspect your head gasket, or perhaps water pump. If it's oil suspect your main bearing seals, but they only usually go with the bearings so you'd be getting rumbling or knocking sounds with that. ____________________ a.k.a 'Geri'
| cp2008 |
| Ben. |
 Ben. World Chat Champion
 Posted: 23:17 - 13 May 2008 Post subject: |
hmm it might have fucked your head gasket where the engines probably been getting too hot meaning coolants been getting in.
if you take it apart there will usually be a really obvious crack as the coolant basically steam cleans the hole.
if not check your carbs, they make the plugs go white if they letting to much air in.
But then ive never seen a spark or piston like that before...
do you use coolant or tap water? ____________________ follow my racing season
Race bike - R6
Road bike - sv650 |
| StealthDJ |
 StealthDJ Nova Slayer
 Posted: 23:46 - 13 May 2008 Post subject: |
White deposits are, suprisingly, common. This site is quite useful:
https://www.theultralightplace.com/pistons.htm
If it's suddenly gone to running very rich, which looks to be the case, I'd make a guess that your main jet is currently sat in the bottom of the float bowl, having just fallen out. Wouldn't be the first time I've seen it...
Other than that, check your crankcase seals. They don't always go with the main bearings and will cause it to smoke like hell if they fail on the clutch side. ____________________ Current garage: VFR800 FI-W | RD500LC YPVS | SV650 K2 | MZ TS250/1 | MZ ETZ251 | BSA WDB40
Previous notables: H100 S2 | CB250NA/B | CB250T | GT250X7 | Z650 B1 | SR650
Still owned, but long gone: RD250LC | CB750F2 SOHC | C50 |
| iooi |
 iooi Super Spammer
| cp2008 |
| The Artist |
 Posted: 14:46 - 14 May 2008 Post subject: |
so was the head gasket fine?
borrow a compression tester and tell us what it is.
Also check the jet in your float bowl like stealthDJ said, i forgot bout that  |
 Posted: 18:52 - 14 May 2008 Post subject: |
StealthDJ has made an excellent suggestion.
If your oil pump had failed you would be doing 3mph, not 30, because you would be pushing it home  ____________________ a.k.a 'Geri'
| Rockhopper |
The last post was made 17 years, 275 days ago. Instead of replying here, would creating a new thread be more useful? |
