New can
WILDECELT
PostPosted: 22:34 - 13 May 2008    Post subject: New can Reply with quote
Hi all
I've just recently purchased a CB 1300 03 model ,well i fitted a after market can on it today ( MRS) and i noticed that although it's sounds lovely and throaty ( the original can is real quiet)it feels slightly sluggish the grunt and torque is not up there any more .
What i want to know do i need to get it dyno jetted and should i purchase a power commander and maybe a K+N filter or is there another way around it ?.
It still pulls like a train when i rev it higher but at low speeds it kinda backfires alot any info would be great
Thanks Smile Thumbs Up Thumbs Up Thumbs Up
stu_m
PostPosted: 00:00 - 14 May 2008    Post subject: Reply with quote
you lose the back pressure with a different can and its the back pressure that makes the bike run right for that mid range
you probably need to have a re-jet done
if i was you i would see if you can open the air box up more and fit a different filter too before the re-jet it will give you that extra omphhh too Smile
Stu
WILDECELT
PostPosted: 00:13 - 14 May 2008    Post subject: Reply with quote
Thanks Stu
being green when it comes to technical stuff how do i open the airbox up more as i said i've just got this bike so it's all new to me : Smile Thumbs Up Thumbs Up
Finglonga
PostPosted: 09:38 - 14 May 2008    Post subject: Reply with quote
If its started backfiring since fitting the new can check for air-leaks at the join. Oxygen being introduced to hot pipe and unburnt fuel = BANG! Wink
Andy Sez....
F.Y.Y.F.F.
stu_m
PostPosted: 10:06 - 14 May 2008    Post subject: Reply with quote
WILDECELT wrote:
Thanks Stu
to be honest im not sure
some bikes you can do others you cant
usually there is loads of emmissions cr*p that can come off too that helps with the running of the bike
have you searched for a cb1300 forum ? i think there is one out there Smile
The last post was made 17 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 44.39 Kb
