unknown leak from middle of CBR125 (where the stand is)
fourten
PostPosted: 21:30 - 13 May 2008    Post subject: unknown leak from middle of CBR125 (where the stand is) Reply with quote
There's a really slow leak (maybe one drop a day or two) of a dark grey metallic thick liquid and i have no idea what it is? I know i'm really silly for not checking it out properly but i've looked and so far can't see where the leak is coming from... Will take a proper inspection tomorrow but wondered if you had any thoughts?
I notice it in the mornings, and every other day there's been a new droplet.
Grateful for any money (two pences)/ advice, cheers
www.artridertraining.co.uk
Paddy Blake
PostPosted: 22:28 - 13 May 2008    Post subject: Reply with quote
Do you oil your chain often.It could just be oil coming from around the
front sprocket that flies of the chain.
Paddy.
Ben.
PostPosted: 23:11 - 13 May 2008    Post subject: Reply with quote
chain lube?
its not petrol, and unless you have freaky coolant or oil i dont know what else it would be, whereabouts is the 'middle' of the bike?
follow my racing season
Race bike - R6
Road bike - sv650
Mudskipper
PostPosted: 08:15 - 14 May 2008    Post subject: Reply with quote
I'd agree on it being chain gunk. I'd take your front sprocket cover off, I bet you'll be horrified at the slime lurking there!
Toothbrush and degreaser (I use Hyperclean) or WD40 is better than nowt.
I'd get it cleaned asap if it is that, as the metallic bits will be grinding your chain down nicely.
Finglonga
PostPosted: 08:35 - 14 May 2008    Post subject: Reply with quote
What does it smell of? If not fuel then as others have said chain lube most likely.
Andy Sez....
F.Y.Y.F.F.
fourten
PostPosted: 22:54 - 14 May 2008    Post subject: Reply with quote
i've toothbrushed and lubed my chain about 2/3 times in the past 2 months... so highly likely to be chain lube as suggested...The 'middle' being where the side stand is (when upright)
No, doesn't smell like fuel... But the chain lube i use is the spray on lubricant - it's transparent yellow in colour and quite runny, not thick and dary grey metallic... But i would guess it's the 'gunk' and grime sticking to the lube.
I've cleaned the chain guard (i use WD40 to clean) i'm quite sure it's pretty clean..and i checked the engine oil level- was over the full mark..
Thanks guys Karma
will give it a proper clean again this weekend to put my mind at ease, and hopefully stop this freak leak.
PostPosted: 23:01 - 14 May 2008    Post subject: Reply with quote
After chain lube has mixed with road grime and sprocket shavings it will be dark grey and metalic.
The last post was made 17 years, 275 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 52.83 Kb
