Getting a welder?
Itchy
PostPosted: 17:01 - 14 May 2008    Post subject: Getting a welder? Reply with quote
I got an angle grinder and now can't think how I'd do without it, then a drill , then more and more power tools,
But one thing that eludes me is a welder , it seems to be such a useful item according to many folks , how much $$$ damage am I looking at for a decent/basic one and what should I look for and of course running costs? .
Alot of my little prototype projects would be possible with a welder,
Any thoughts?
Ta
Robby
Dirty Old Man
PostPosted: 17:53 - 14 May 2008    Post subject: Reply with quote
Welder is a great tool to own.
My one - description and costs.
MIG welder - weldspares 100a, 4 power settings and variable wire feed speed. Fairly normal hobby welder. Can weld continuously for about 20-30 minutes, then it needs to cool down for at least an hour. Can take 0.6 or 0.8mm wire as it is, could probably get the right feed wheel to use thicker wire, but I don't think the welder is powerful enough to make it worthwhile.
I use it to weld mild steel square bar, and up to 3mm plate for the car I'm building.
Cost me £55 second hand on ebay. Came with:
Spool of 0.6mm wire (already on there and set up)
CO2 gas regulator
Mostly empty bottle of CO2 (pub canister)
Bits I have bought:
0.8mm welding wire (0.8kg spools, one of them lasts a good while). £5/spool.
Converter to use my CO2 regulator on an Argon bottle. £8.
Tips, shrouds, gas feed line. ~£15.
Welding mask - cheap auto reactive one off ebay. £25.
Gas bottle - £40 deposit, £25 refill with argon (argoshield light).
Things I have learnt - total novice.
If your gas bottle is empty, or you're not using gas, your welds will be shit and penetration will be poor.
Argon produces better (easier) welds than CO2.
Practice on scrap metal of a similar thickness to what you will be welding.
Have a look online for a MIG tutorial - the first ones to come up on google are good.
You use different wire to weld aluminium than you do for steel.
Gasless MIG is a bit crap. ARC is cheap and nasty. TIG is expensive and very nice. MIG is good for a beginner and puts down good welds. Oxy-acetylene is lovely to play with and versatile, but you need to get the gas, and store it safely.
WildGoose
White Van Man
PostPosted: 18:16 - 14 May 2008    Post subject: Reply with quote
I bought one, but I havent started actually welding stuff properly yet. As finances aren't allowing at the moment.
Clarke 151EN Turbo Gas/No Gas - new, so was expensive, Clarke is considered the superior make among the hobby welders, going by what the folk on the mig welding forum say. It was £200 quid.
It is set up for gasless, but I intend to use gas, mainly because the flux cored gasless wire is so damn expensive £50/5kg spool, compared to 5-10 quid per spool of the standard wire.
It can use 0.6 and 0.8 standard wire, and obviously 0.9 gasless wire.
Lots of people use CO2 pub gas cos they can get it cheap, but BOC argoshield is the stuff to use, if you want a tidy result. It's not cheap, but its cheaper than using the gasless wire or cocking up the welds.
https://www.mig-welding.co.uk/forum/index.php - This site also hosts the tutorials that I think robby mentioned.
I intend to use mine mainly for welding my van back together, since no panel on it is thicker than 2mm, I doubt I will ever get near the 150 amps its capable of, but its nice to have so I can draw my focus to other projects later on.
MIG welding is accepted as the easiest welding form for beginners, and gives fairly decent results, but proper preparation of the metal is the key to everything, the welding process itself is a matter of seconds.
Take proper precautions regarding the possible damage to eyes and skin from the arc, decent helmet, gauntlets, and 100% cotton clothing. Fire extinguisher/bucket of sand wouldn't go amiss either.
[EDIT] Get a welder designed to be used in a standard 13amp house socket, otherwise you may do some damage, or have to get a dedicated circuit made up, similar to what an electric cooker would require.
Use a residual current device when the welder is plugged in, and replace the plug every 6 months to a year.
Duty cycle, refers to the percentage of a 10 minute period that the welder is capable of welding for, until it needs a rest, the higher the amps the lower the duty cycle for a particular setting. The higher quality the welder, the higher the duty cycle, generally.
For example, 60% duty cycle at 100 amps, would allow you to weld at that setting for 6 minutes, before having to rest the machine for 4. At low settings such as 30 amps, my machine claims to have a 100% duty cycle.
Read the manual, manufacturers will advertise their machine at the maximum amps most likely, but may neglect to mention it can only produce those amps for 30 seconds before cutting out.
b-f-c
PostPosted: 10:28 - 15 May 2008    Post subject: Reply with quote
What they said, and buy the biggest amp unit you can afford - they higher the amps the better range of welding you can do. 150 - 180 should cover you if you're going to play around with frame welding
PostPosted: 09:32 - 16 May 2008    Post subject: Reply with quote
I'd really like a TIG welder (as I can actually TIG weld...) but I can't afford one! Sad
I'm thinking actually a small lathe would be the first thing on my list before a welder perhaps... but thats just me.
I really want a big workshop with loads of kit in it. But I can't afford it.
Maybe I need to do some more overtime...
Shaane
PostPosted: 14:09 - 16 May 2008    Post subject: Reply with quote
Don't they cost like 600+?
My dad is looking for one as well... All the reasonably good ones hes looked at are so much. But i don't get why they are such a lot more than a MIG welder?
Previous: 1992 DT125R
Current: ~ 2005 ZX6R C1H
ZRX61
Victor Meldrew
PostPosted: 16:49 - 16 May 2008    Post subject: Reply with quote
Best gas for Mig is C25: 75% CO2/25%Ar.. & buy the biggest bottle available, usually about 175Cu/Ft
ZRX61
Victor Meldrew
PostPosted: 16:53 - 16 May 2008    Post subject: Reply with quote
Because Tig can weld just about any metal whereas Mig is basically limited to steel & aluminium.. & you can use a tig for stick welding. Mine was about $2400, the one I want* is almost $7000
*don't actually need it, just want it..
Stevep
PostPosted: 17:00 - 16 May 2008    Post subject: Reply with quote
As a class one welder TIG is by far the way to go welds are better and cleaner no splatter and what is more to the fact neater but they are more expensive. They can be bought at places like Machine Mart or even on ebay but the best place to look out for them is at a auction when a manufacture has shut down.
That is where I got my last one from and they use argon as well from boc
Harleys run Forever
ZRX61
Victor Meldrew
PostPosted: 17:04 - 16 May 2008    Post subject: Reply with quote
And don't buy some Chiwanese POS, You can never get parts for them (or even a wiring diagram).
Who makes the good ones on the UK? Do you get Miller, Lincoln, Hobart or Esab?
tutton
PostPosted: 21:00 - 16 May 2008    Post subject: Reply with quote
Never heard of any of them welders. Laughing
Cammy
PostPosted: 21:12 - 16 May 2008    Post subject: Reply with quote
Used to use the Gas welders, pretty cool stuff - the ammount of times i burnt my hand on the metal thinking it had cooled down, and thats with heatproof gloves Rolling Eyes
But welding isnt a first timer job if your gona use it straight away even electric welding - you gota have the right speed and tempo of moving the metal lava and its not easy.
I dont know who makes Welding kits but try going down to your local willy wilsons or any electrical wholesaler for directions of who sells them and for good prices, maby a local garage will maby have an old one they dont need? Razz
~Cammy
Theory: Passed | A2 Restricted Test: August 8th |
Currently Riding a Aerox Rossi 50R (rossi replica moped Mad) / CG 125 /Kawasaki Ninja ZX6R
Itchy
PostPosted: 21:23 - 16 May 2008    Post subject: Reply with quote
Right thanks,
I think that I shall go do some night classes on welding before I actually decide to get one to try before I buy in essence,
all my projects seem to involve welding box section steel into corners , I'm sure I can just make flanges and bolt ends on for now, just looks awful!.
gmanxiii
PostPosted: 21:33 - 16 May 2008    Post subject: Reply with quote
wanna help me weld some bolts to me snapped studs? Razz
I kills hondas
VFR400NC30 > ZZR600 > CBR600FX > CBR1000rr
WildGoose
White Van Man
PostPosted: 21:36 - 16 May 2008    Post subject: Reply with quote
ZXR61 mentioned ESAB and Lincoln, you can get both of those makes in the UK, and they are both proper decent quality, but also serious money for hobby welding.
Clarke seems to be the top of the tree in most peoples opinion for hobby welding, SIP one of the worst.
Talk to a member on the mig welding forums called 'weldequip' he sorted me out with all my gear, and knows his stuff.
another good site for info and tips..
https://www.markthewelder.co.uk/index.html goes as detailed as you could possibly want to know, although the "brain dump" style is a bit much for me at times.
Ichy
PostPosted: 21:44 - 16 May 2008    Post subject: Reply with quote
Hard to get in the UK. The high end stuff tends to be Murex/Esab, Kemppi, Migatronic, Butters. Lots of cheapish hobby stuff, sealey, clarke, cebora, sip.
You can get a cheap Tig setup for around £200 by Wolf. I've tried it a few times and while its nowhere near the setups at work it is still ok for the garage. It takes a bit more time and effort to get a decent finish, its all in the gas!
What a lot of people overlook is the power supply. The supply to your house may be able to just supply 150 amp max, probably closer to 120amps. Turn on a couple of appliances and your down to 100-80 amps if your lucky. The supply to my workshop was upgraded to 200 amp with one dedicated socket for the welder, I'm just glad I didn't pay for it.
ZRX61
Victor Meldrew
PostPosted: 16:44 - 17 May 2008    Post subject: Reply with quote
https://www.millerwelds.com/products/tig/dynasty_350/
ZRX61
Victor Meldrew
PostPosted: 16:45 - 17 May 2008    Post subject: Reply with quote
These are pretty sweet:
https://www.millerwelds.com/products/multiprocess/xmt_350/
tutton
PostPosted: 16:46 - 17 May 2008    Post subject: Reply with quote
Just found out
all the ones we used in college
were Kempi
or however you spell it the red ones Smile
and cheers for the linkeh.
The last post was made 18 years, 150 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.47 - MySQL Queries: 13 - Page Size: 107.65 Kb
