adjusting the gear level angle on the hornet???
Blunet600
PostPosted: 23:01 - 14 May 2008    Post subject: adjusting the gear level angle on the hornet??? Reply with quote
The angle the gear lever is at on my hornet means that i have to move my foot to a facing outwards position rather than resting it under the gear lever because if i do rest it under the gear lever my foot stops it moving down enough to slot into gear properly. Can it be adjust so the lever is slightly higher?
PostPosted: 23:07 - 14 May 2008    Post subject: Re: adjusting the gear level angle on the hornet??? Reply with quote
Have you actually looked at the lever? It is generally fairly self expanitory, post a pic of the lever and linkage.
If it is a lever over a star type peice just unbolt it and raise it up a notch, if it is the adjustable linkage type have a play with the nuts on it.
cestrian
PostPosted: 23:08 - 14 May 2008    Post subject: Reply with quote
Yes it really is that simple Smile
The last post was made 17 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 35.33 Kb
