Why is my ped only doing 40mph?
Kizza This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
asdf
PostPosted: 00:14 - 15 May 2008    Post subject: Reply with quote
Im not sure if there is a variator restriction on speedfights but if there is it is a washer in the middle of the variator which stops the two halfs coming completley together. This can effect the top end quite a bit.
https://www.scootnfast.com/images/derestrict04.jpg
If there is one it should look something like that.
Devans
PostPosted: 00:23 - 15 May 2008    Post subject: Reply with quote
There are numerous reasons why, even though you have a racing pipe, has it had the restricter removed from it, it's in the top of the manifold?
it won't have a resonator tube on it anymore so that's fine.
Also the CDI won't stop the scooter from speeding up, when your going down hill, because it's half coasting. that's £18 to get done.
The washer in the variator as mentioned above needs removing.
With a new exaust and rollers you need to get the carb re-jetted i think, but don't quote me on that Razz
Can't think of anymore, it should do 50mph with all that done tbh.
matt_uk
PostPosted: 01:47 - 15 May 2008    Post subject: Reply with quote
Because its a ped... Thumbs Up
- - - BIKE - - - Passed CBT : 21/07/06 - - - Currently : Riding a 2001 Aprilia rs125 (SOLD)
- - - CAR - - - Passed Theory 20/07/06 - - - Lessons, Test on 15th Jan 08... Passed 2 minors
druidsam
PostPosted: 08:40 - 15 May 2008    Post subject: Reply with quote
Laughing Laughing Laughing Laughing
......................Sam
trust me! I'm a druid
https://www.bikerforum.co.uk/
PostPosted: 08:58 - 15 May 2008    Post subject: Reply with quote
You don't have to do anything on a Speedfights CDI when de-restricting. It's just an exhaust and variator restriction.
My guess is that the variator has ben de-restricted but the exhaust hasn't. I can hit 40mph with a restricted exhaust.
southeastpete
PostPosted: 09:25 - 15 May 2008    Post subject: Reply with quote
beat me to it matt...
Devans
PostPosted: 14:03 - 15 May 2008    Post subject: Reply with quote
Nope those 6.7 is quite heavy, any heavier an acceleration will suffer.
Something hasn't been de-restricted, my ludix 50cc ped does 45mph with only a de-restricted exhaust, so something isn't right on yours matey.
i'm 11stone aswell so weight isn't the issue.
How old is your Speedfight?
My mate had an 07 so i'll ask him, if yours is the same age?
Because his had a Rev limiter/CDI on it or something, i can't remember exactly what though.
Get back to me with what year it is an i'll find out exactly what restrictors you've got in yours.
The Artist
PostPosted: 15:29 - 15 May 2008    Post subject: Reply with quote
i see matt_uk and southeastpete had the same idea as me Very Happy Very Happy Very Happy
Andy levitt
PostPosted: 15:37 - 15 May 2008    Post subject: Reply with quote
Have you taken the plate out of the variator? As my speedfight got just over 40 with that taken out and a standard restricted exhaust. I got about 50 mph with a viper exhaust and derestricted variator. your exhaust and rollers should be fin. It must be that the plate is still in. Have a word with that mechanic or better yet just whoop it out yourself. Although youll need an impact wrench costs about £15-£25 methinks. PM if you decide to do it yourself and ill give you specific instructions.
Speedfight 50 -> Honda NSR 125 -> Y reg YAMAHA YZF R6 -> 08 YAMAHA YZF R6 -> Honda CBR1000RR
Theory test Done 4/6/07
Practical test Done 21/12/07
PostPosted: 16:06 - 15 May 2008    Post subject: Reply with quote
Kizza wrote:
The washer was took out when de-restricted and also the exhaust is de-restricted, A bloke mentioned the rollers are too light??
Just because you were told the exhaust was de-restricted, doesn't mean it has been. I'd take the exhaust off and look inside it where the pipe meets the engine. There will be a smaller washer if it's restricted, if it's de-restricted it won't be there and would have been drilled out.
Take it off and take a picture of it Thumbs Up
Also it's doubtful that you will be hitting 50mph, 45mph is more realistic.
PostPosted: 16:11 - 15 May 2008    Post subject: Reply with quote
It could be his exhaust is still restricted as even you just said that with a de-restricted variator and a restricted exhaust you were hitting just over 40mph.
I ride with a de-restricted variator and a restricted exhaust and can get just over 40mph on a good day.
PostPosted: 09:06 - 16 May 2008    Post subject: Reply with quote
I'm going to derestrict my daugters Gilera DNA. The only thing I'm not sure about is what the rollers do and how the different weights affect the bike.
Can someone explain why I should change them.
Triumph Trophy Launch Edition
Devans
PostPosted: 09:37 - 16 May 2008    Post subject: Reply with quote
The rollers effect the topspeed/acceleration of a scooter.
Here's a link which will exsplain it all Smile
https://www.teamcalamari.com/zuma/variator.html
cestrian
PostPosted: 10:36 - 16 May 2008    Post subject: Reply with quote
Note....
Motors with standard carburation are set up at the factory. If you change to an aftermarket exhaust or derestrict a standard exhaust, you will affect the carburation (fuel/air mix), the motor will be running 'lean' and will therefore run hotter than it should. It will probably suffer some power loss and at worst, sieze entirely.
You need to adjust the fuel/air mixture to get best performance and reliability.
Damon
PostPosted: 20:51 - 16 May 2008    Post subject: Reply with quote
Kizza wrote:
I know for a fact the exhaust has been de-restricted as the mechanic gave me the cone shape restrictor thing and the old rollers, and the washer from the variator in a polythene bag. As for the year of the ped it is an 07, Rally Victories Edition. Today i went out and bought a size 58 carb jet and malossi 8 gram rollers, I was advised on the bigger jet and the rollers from 6.7 to 8 gram will improve top speed significantly?? Cheers for all the replies guys Very Happy
Fact is, its a ped. No matter how much you spend on it, you wont get it going that fast. Just make it un reliable.
As stated above, check to see if the washer is still in the exhaust. the 58 jet might make the bike run rough to be honest.
frantic_2003
PostPosted: 00:08 - 17 May 2008    Post subject: Reply with quote
maybe because its a ped?
https://www.bikepics.com/members/frantic/
PostPosted: 07:05 - 17 May 2008    Post subject: Reply with quote
Rolling Eyes
AppleJoe
PostPosted: 13:58 - 18 May 2008    Post subject: Reply with quote
Stop double posting to bump your thread Neutral
Full licence from 16/4/08 Smile
Previously: '56 YBR125 - Current: K1 SV650S
Kizza This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
The last post was made 18 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 128.74 Kb
