braided hoses, front only?
t121anf
PostPosted: 11:41 - 18 May 2008    Post subject: braided hoses, front only? Reply with quote
is it ok to fit braided hoses to the front brakes only?
i own a kit on eBay (well my dad did since i was in crete) but its the fronts only, should i just fit them or should i buy the rears too?
i personally can't see a problem with fitting just the fronts but felt i should check.
Sparks!
Sir Tart-a-lot
PostPosted: 11:47 - 18 May 2008    Post subject: Reply with quote
There is no problem with this whatsoever... as long as you replace both lines if they are dual lines.. You don't have to do the rear if you don't want to... and vice versa
t121anf
PostPosted: 12:04 - 18 May 2008    Post subject: Reply with quote
thought as much. just need to get some pads now and hope for bad weather to change them (will want to be out otherwise)
TheDonUK
PostPosted: 12:31 - 18 May 2008    Post subject: Reply with quote
i just put a pair of goodridge hoses on the front of my hornet, BIG imrprovement over the OEM rubber hoses. The front brake gives feedback now rather than squeezing on a soggy rag.
Do eit Razz
Doddmaster
PostPosted: 13:39 - 18 May 2008    Post subject: Reply with quote
They made a massive difference on my Firestorm. Going from standard lines and Honda pads to braided hoses and Carbone Lorraine pads was a hell of a change
The last post was made 18 years, 132 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 42.98 Kb
