My bike soon running.....
ilovens125f's
PostPosted: 21:49 - 26 Feb 2004    Post subject: My bike soon running..... Reply with quote
Hi guys,
Its me again my piston, cylinder and crack came back 2 day, I'm well chuffed Laughing Thumbs Up .Looks like i will be riding my bike by Sunday!!! Its now a very speical ns150f and with a brand new crank and roller bearings (big and small end) its gonna b great!! Pics to follow
P.s. Does any one know the running in period for a ns125f (ns150f Thumbs Up Cool as the bloke that did my bike bits said
150 to 200 miles (the engin is a 1989)
Thanks
Kev
Kev the Ns125F lover!!
!!!Dont ignore me!!!
ilovens125f's This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
Robby
Dirty Old Man
PostPosted: 22:08 - 26 Feb 2004    Post subject: Reply with quote
ok then.
Ian (GPX) This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
mr jamez
PostPosted: 22:14 - 26 Feb 2004    Post subject: Reply with quote
cool Thumbs Up Smile
Don't think I'm going to get my NSR on the road this year; haven't even paid for it yet Laughing
stevo as b4
PostPosted: 23:51 - 26 Feb 2004    Post subject: Reply with quote
Its open to opinion on how long you should run in a 2-stroke engine. Some manufacturers say as much as 1000mile, but others 500mile. In some ways a two stroke should need less running in than a 4 stroke, as there are only 3 moving parts. But 2 strokes run hotter, and the lack of positive lubrication means that its vital to get a good piston to cylinder surface for long engine life and to prevent seizure. On MX bikes they sometimes say that the first tank of fuel is enough to run it in, as any longer period would detract too much life span from the piston/rings. That might well be true on a motor in that state of tune, but on a road bike i would take a bit longer. What type of cylinder does the NS have, i.e. Nickosil plated, or a steel/iron liner? I think that also makes a difference, as bikes with plated bores run closer piston to cylinder clearances than cylinders with liners fitted. I would do the first 100mile really steady, less than 1/2 throttle, and 5k rpm. Then after the first 200mile id would gradually increase throttle use and max rpm, so that by around 400-500mile you will be able to use full throttle and rev the motor out, but just occasionally, and keep your cruising speed down, but gradually work up to full performance. With experience its easy to tell when a motor is loosened up, but its even more important on a stroker not to put too much load on it for the first few hundred miles, so use the gearbox more, and never let the motor work hard in a high gear. Also its best to vary the speed, so that you dont ride everywhere at say 50mph, to let the motor get used to different loads, and speeds, instead of just crusing on a constant throttle everywhere.
ilovens125f's
PostPosted: 17:35 - 01 Mar 2004    Post subject: My bikes running Reply with quote
Hi guys I said I would keep you posted and I am
I got my bike running on friday night but i put the
clutch back toughter wrong and had to take it appart
four times until I got it right but when done it all worked
fine.Only problem is that when I was out on the road
I cant rev up above 5 tho revs but when running it was
fine any thougths??????
Thanks
Kev
The last post was made 22 years, 233 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 52.54 Kb
