Motorhispania RX50
DRZ400SM
PostPosted: 13:17 - 24 May 2008    Post subject: Motorhispania RX50 Reply with quote
I've had motorhispania rx50 lying about in my back garden for about 2 years. i got it when i was 16 as "non runner" but only needed very little work which i never got round to sorting and as you can imagine now needs more than "a little work". now i don't know much about the mechanics of a bike but would like to fix it up as a first project.
I was thinking put a new engine in it and go from there would this be the best way to go about it or do you guys have any better ideas as to what i could do with it as i don't want to see it go to total waste
Shane
The Artist
PostPosted: 15:40 - 24 May 2008    Post subject: Reply with quote
I have an rx50 as you can see in my picture.
The engine is pretty standard depending on what year it is and parts are readily available.
You can do lots of things but it depends what your budget it.
Post some pictures and check the bike yourself if there is any major damage or wear.
Check simple things like,
is the engine seized, does it spark. Does it have compression.
If you want, PM me and I can help.
DRZ400SM
PostPosted: 20:31 - 24 May 2008    Post subject: Reply with quote
Thanks for the reply.
I took some pics earlier. When I tried to get it out the corner the wheels wouldn't move maybe chain and sprocket? as the chain was solid no movement at all!
Also panels are bit shabby but know someone who is bit of a dab hand when it comes to that sort of thing and will get it looking really good
Engine wise was thinking something like Aprilia rs50 or maybe 125 if it would fit but anything as long as it works Very Happy any sugestions?
Anyway heres the pics let me know what you think
https://i284.photobucket.com/albums/ll3/DRZ400SM_2008/RX50/S6300206.jpg
https://i284.photobucket.com/albums/ll3/DRZ400SM_2008/RX50/S6300208.jpg
https://i284.photobucket.com/albums/ll3/DRZ400SM_2008/RX50/S6300204.jpg
https://i284.photobucket.com/albums/ll3/DRZ400SM_2008/RX50/S6300203.jpg
https://i284.photobucket.com/albums/ll3/DRZ400SM_2008/RX50/S6300210.jpg
https://i284.photobucket.com/albums/ll3/DRZ400SM_2008/RX50/S6300207.jpg
PostPosted: 07:45 - 25 May 2008    Post subject: Reply with quote
Could you not possibly fix the engine that is in it?
Why was it sold as a non-runner?
The Artist
PostPosted: 08:00 - 25 May 2008    Post subject: Reply with quote
Looks just like mine but rusty Very Happy
Ok, do a quick check to see if its worth keeping the engine and using that one.
Remove the spark plug, pour some 2 stroke oil in, lots!!!
Attach a battery and connect, press the start button. Do not hold it on, just see if it turns over, don't keep turning it over as you may damage something in the engine as you don't know the condition.
See if it turns over. If not it is seized which could be freed up but on a high rpm bike like this it probably won't do it any good.
If it does turn over then you may be able to get it running.
Report back to us when you have done that.
The engine is pretty much the same as rs50 etc but different years have different engines. Yours looks just like mine but unfortunately I don't have a spare. If you need any parts apart from the engine, I have them, forks, yolks, radiator, wiring loom, frame bits, brake callipers etc etc.
There is a gap of 5 years, 231 days between these two posts...
ramarg
PostPosted: 12:22 - 10 Jan 2014    Post subject: furia 50 cc Reply with quote
Hi im looking for kick start parts for a 03 furia, anyone got any for sale ?
thanks
bikersupermot...
PostPosted: 16:58 - 10 Jan 2014    Post subject: Re: furia 50 cc Reply with quote
thanks
which kick start parts exactly? these bikes use parts from the aprilia / derbi / motorhispania / peugeot / beta /gilera common parts bin and most but not all use the minarelli engine or a variant of it.
so you ll likely find the same part on one of the other makes of bike if not a motorhispania.
tinybikes
The last post was made 12 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 53.42 Kb
