quickshifters - anyone got one?
Keir
PostPosted: 15:30 - 27 May 2008    Post subject: quickshifters - anyone got one? Reply with quote
thinking of a dynojet one. seems to be the least complicated although it cuts the fuel not spark so i wouldnt get the racing style backfire every gear change. Crying or Very sad
anyone got one? worth it?
Current : '08 Yamaha FZ1s
Finglonga
PostPosted: 15:38 - 27 May 2008    Post subject: Reply with quote
Why would you want one? is it for a track bike or by the sounds of it just to impress the pre teen girls? Waste of money for day to day riding on the roads. Confused
Andy Sez....
F.Y.Y.F.F.
PostPosted: 15:43 - 27 May 2008    Post subject: Reply with quote
Apparently the trans-logic quick shifters are highly recommended.
I guess you want the dyno jet ones because they go straight into your PCIII though right.
Keir
PostPosted: 16:03 - 27 May 2008    Post subject: Reply with quote
Finglonga: I assume you dont have one then? thanks for your input all the same.
Big_Ham: Yes i did select the dynojet one due to its plug and play nature. If its made to work with items already on the bike then it makes life much easier.
PostPosted: 16:06 - 27 May 2008    Post subject: Reply with quote
If it was just cutting the spark then you would get a bang, which will damage your exhaust as time goes on.
Most are probably spark based as they have been around since the year dot and were designed to work on carbed engines.
base
PostPosted: 16:13 - 27 May 2008    Post subject: Reply with quote
i run a translogic system on my 92 blade, is it a gimick on the road ...............yes so is having nitrous, but i still have both of them, if we were all the same it would be boring, if you want one can afford one buy it.
cyclops12
PostPosted: 18:03 - 27 May 2008    Post subject: Reply with quote
got a klicktronic on my trike and love it
its electric only use clutch for downshifts and pulling away
https://www.kliktronic.co.uk/
hayabusa trike
leatherpatche...
PostPosted: 21:14 - 27 May 2008    Post subject: Reply with quote
The one that goes into the power commander cuts the fuel, not the spark. I've heard mixed reviews.
Grazo
PostPosted: 09:56 - 16 Nov 2008    Post subject: Reply with quote
Flatshifter do 2 systems, one cuts the ign and the other the fuel neither backfires through the exhaust they have a soft restore system apparently which ramps back in slowly after the "cut" you can also do clutchless downshifts with them .
graz
Keir
PostPosted: 18:51 - 16 Nov 2008    Post subject: Reply with quote
awoken from the grave..... irrelevant now thanks mate, i got the quickshifter back in may.
The last post was made 17 years, 304 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 63.98 Kb
