Performance ECU... and a noob question
Mac_Black
PostPosted: 23:10 - 29 May 2008    Post subject: Performance ECU... and a noob question Reply with quote
Firstly I've allready stated that I'm interested in unleashing my horses in the best way possible, so is this genuine? https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=250250524881&_trksid=p3907.m32&_trkparms=tab%3DWatching
Reply quick! Shocked Wink
Now as for the question, which relates to these:
https://www.inter-bike.co.uk/inter-bikeshop/admin/images/accessories/anbarendcr.jpg
...Ahem Shifty ... How do I fit them? Embarassed
I've had to use a clasp-grip tool thingy to hold the sleeves whilst I tightened the allen key and then I hammered them in, there in but not tight enough and will move/ vibrate out... What a headache. Binge! you know how these awful contraptions opperate Laughing
PostPosted: 07:15 - 30 May 2008    Post subject: Reply with quote
CDI unit might well fix the top speed restrictor and raise the rev limiter (which you might not want to be raised). However it is down to how well the timing curves in it are set up. Could be fine, could be a nightmare.
As to the 2nd, take out your old bar ends and put those ones in place. Tighten up the allen key and the inner part forces the outer part to expand to hold them in place.
Mac_Black
PostPosted: 11:58 - 30 May 2008    Post subject: Reply with quote
Yeh thats the bit I'm struggling with. Crying or Very sad
PostPosted: 12:02 - 30 May 2008    Post subject: Reply with quote
As you tighten the allen key it pulls the inner part towards the allen key. Doing so it forces the outer sleive out, until the whole thing stays in place.
Some stock bar ends are held on the same way but using a rubber bung with a nut in the middle. Tightening a bolt in the nut squeezes the rubber out until it is held in place.
Be away that getting rid of the weights like this might well cause some vibration to be noticeable.
Mac_Black
PostPosted: 16:21 - 31 May 2008    Post subject: Reply with quote
Thankyou Keith, I don't mean to be rude but I know how it's suppose to work, it's a very simple 'mechanism' but what I'm saying is that they're very fiddly to fit, they DON'T grip the inside at the moment so I can't tighten them properly.
Thankyou though, with regards to the CDI I know its a dumb question but do you think it'll suit my needs?
I'm after;
Arrow More power.
Arrow 135-140mph? Indicated top speed
Arrow Smoother running
In short I want my bike to perform to its best abilities...
Is that CDI unit suitable or would I be better off looking elsewhere?
Thanks again Thumbs Up
virus
PostPosted: 16:32 - 31 May 2008    Post subject: Reply with quote
Tighten the up until they start to 'bite' before putting them in, this stops the system just spinning and not tightening when you use the Allan key.
John
own: 81 xs1100g...
PostPosted: 17:57 - 31 May 2008    Post subject: Reply with quote
Mac_Kaliba wrote:
Arrow More power.
I wouldn't touch it personally. Can't you get a HRC CDI?
I wouldn't touch a chinese CDI from ebay with a 10 foot pole, but that's just me.
PostPosted: 19:37 - 31 May 2008    Post subject: Reply with quote
As above for the bar ends.
With the cdi it depends on how much you trust it. Could be fine. Could burn holes in the pistons when you next thrash it.
Mac_Black
PostPosted: 22:34 - 31 May 2008    Post subject: Reply with quote
Ahhh there you go thats allright then, I thought I saw one but was'nt sure, I'll have a dig and wait for a HRC unit to pop up.
Many thanks everyone, karma for all Mr. Green
Eh? ...I've just realised this should have been started in the workshop section. Ohwell Surprised
hmmmnz
PostPosted: 23:27 - 31 May 2008    Post subject: Reply with quote
as for cdi...... the vfr rvf were never restricted via the cdi, some had a speedo restriction in the clocks. which is pennies to sort out.
a rev limiter is there for a reason. disabling that, is just dumb, by the time you hit it you are already past peak power and torque
the humans are dead
I kick arse for the lord
Mac_Black
PostPosted: 00:29 - 01 Jun 2008    Post subject: Reply with quote
Hold on I'm confused now, my bike currently does around 120 indicated, do I need the CDI to get 135-140 or not, I know it won't redline in sixth I think it maxes at about 11-12k Confused
neatbik
PostPosted: 05:59 - 01 Jun 2008    Post subject: Reply with quote
Arent you on a 33bhp license?
hmmmnz
PostPosted: 08:02 - 01 Jun 2008    Post subject: Reply with quote
the vfr was never cdi restricted except by the speedo
if you are getting to 120, then its fairly safe to say that your bike is not restricted.
https://members.aol.com/sbirring/rvf400.htm
the humans are dead
McGee
O RLY?
PostPosted: 08:12 - 01 Jun 2008    Post subject: Reply with quote
Ride it off a cliff it may reach a velocity of 140mph (with you still on it) before it hits the ground. Wink
Its pronounced Jixxer!
Knacker
PostPosted: 09:32 - 01 Jun 2008    Post subject: Reply with quote
Sell it get a GSXR6 Very Happy
Previous: K1 GSXR 1000
PostPosted: 18:00 - 01 Jun 2008    Post subject: Reply with quote
If you fit an MPH converter to the speedo that's enough to de-restrict it, since it's restricted by the clocks.
The last post was made 17 years, 205 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 95.38 Kb
