whats the right oil?
mikey c
PostPosted: 16:29 - 02 Mar 2004    Post subject: whats the right oil? Reply with quote
what oil do i need to use in CBR600 F1, four stroke, wet clutch, in the book it says 10w-40 but does this have to be special stuff, or will car engine oil do, and if car engine oil is put in, will it do any damage Embarassed ?
mike
craigT19
Jolly Green Giant
PostPosted: 16:33 - 02 Mar 2004    Post subject: Reply with quote
Please do not use car oil, bike oil is specifically desighned to operate at the temperatures that a bike does, car oil will be too thick and i've been told will not protect your engine properly.
I can highly recommend castrol GPS most of the guys i know use it, and i don't know anybody who has had a problem yet. And it isn't that expensive.
regards
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
dainesefreak
PostPosted: 16:35 - 02 Mar 2004    Post subject: Reply with quote
Did you buy the bike from a dealer? If so and you intend on getting it serviced there it may well be worth while asking what oil they use and recommend. Then you can stick to using the same stuff as them.
carvell
Scuttler
PostPosted: 16:40 - 02 Mar 2004    Post subject: Reply with quote
Go to Halfords and pick up some bog standard 10w-40 4-stroke motorcycle oil - they always have loads, it's cheap and works fine!
Yamaha TDM 850
mikey c
PostPosted: 16:45 - 02 Mar 2004    Post subject: Reply with quote
ok cheers, i did put car oil in but its only been started for a couple of minutes since then, so hopefully no damage! i didn't buy it from a dealer nor is it in a bike, its a project i've just aquired
where can i buy bike stuff then? where do you guys get it from? dealers, motor factors, halfrauds, specialist bike places? and where can i get a good oil filter from?
thanks for the help!
mike
edit: i take too long to post, i guess its a trip to halfords then!
Hex
Party Boy
PostPosted: 16:49 - 02 Mar 2004    Post subject: Reply with quote
Halfrauds will sell it, just get a semi-synthetic.
The car oil wont of damaged the engine, as in essance it will have the same basic properties, so don't worry about that since its only been ran a short amount.
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
carvell
Scuttler
PostPosted: 16:51 - 02 Mar 2004    Post subject: Reply with quote
You could order one over the phone from your bike manufacturer, visit a website such as gear4bikes.com, or go to your local motorcycle shop.
Halfords also do a limited selection of motorcycle filters.
Yamaha TDM 850
PostPosted: 16:53 - 02 Mar 2004    Post subject: Reply with quote
Best place to get your bike oil from is any good motorcyle shop Smile . Or you can order from any online shop type place like www.demon-tweeks.com or any of the ones listed in the links section.
I would advice against using car oil, as cars do not have wet clutches, and so the aditives in the car oil damage the clutch plates. I put some in my ZX6R once just to top it up as it was low, and within about 10 minutes the clutch was worn out. Surprised
Expect to pay about £20-35 for four litres of oil, and about £8 for a decent K&N oil filter.
If it's been in the bike ten minutes, I wouldn't be suprised if it has already soaked into the clutch plates. Confused Neutral
Robby
Dirty Old Man
PostPosted: 16:59 - 02 Mar 2004    Post subject: Reply with quote
It all depends on the oil used and the vehice it was used in. I used car oil in my VX for the last 2000 miles and had no problems. This was bog standard 15W40 mineral oil, it worked fine.
Car oils don't attack clutches, they can over lubricated clutches and make them slip, but it won't matter if its mineral oil. A 10W40 mineral oil is a 10W40 mineral oil. It contains no additives, so is suitable for cars and bikes.
monkeyman
PostPosted: 17:44 - 02 Mar 2004    Post subject: Reply with quote
Noob question.
What do the numbers stand for?
Im not the best, but im in the top one
RM 250, Husky TE610, K1 GSXR 750
PostPosted: 18:57 - 02 Mar 2004    Post subject: Reply with quote
I use car oil in the bikes most of the time. Not yet had a problem with the clutch. The original Bandit engine did over 30000 miles on car oil with no sign of clutch slip. A friend has an FZ750 with over 70000 on it which has happily run on semi synthetic car oil through most of its life. On the other hand, even if it did then changing the clutch plates on an FZ750 is a fairly fast job Cool .
Bike engines will kill oil quicker, basically due to sharing the oil between the engine and the gearbox. The gearbox does a good job of chopping up the oil. A bike engine does not necessarily run any hotter than a car engine.
The numbers in the oil rating describe the viscosity. A 10W40 oil behaves as a 10 weight oil when cold and a 40 weight oil when hot (this does not mean that the oil gets thicker as it heats up, just that it does not thin out as quickly). The W stands for winter.
Mineral oils DO contain additives. Indeed they contain more viscosity enhancing additives than synthetic oils. As it is these additives that break down (so what was a 10W40 oil when new degrades to a 20W30) and synthetic oils rely on them less it is often said that you can stretch out oil change intervals for longer on synthetic oils.
It is probably best to avoid the highest spec car oils. The highest grades (eg, the bit that says SF, SG, SH, etc) are designed for modern catalysed cars. Some of the most efficient additives to protect engines also happen to damage catalytic converters when burnt (and some oil will always be burnt). Therefore the newest grades have a limit on how much of these additives they can use. Think that refers to SJ spec oil.
Mr C
PostPosted: 23:51 - 02 Mar 2004    Post subject: Reply with quote
Also, conventional wisdon seems to be to avoid fully synthetic oils in newish big bikes as it stops the rings bedding in
not sure about that but "they" also say that it can affect clutch performance on more powerful models
I stick with Silkolene semi synth 10W40
187.3bhp = 201mph
andrew
Mister Road Rage
PostPosted: 13:32 - 03 Mar 2004    Post subject: Reply with quote
Isn't 10w 40 synthetic car oil exactly the same as 10w 40 synthetic bike oil? Correct me if i'm wrong but isn't that what the ratings are for? I've used car oil in my bike with no problems whatsoever.
Stew
If it's good enough for top race teams...
PostPosted: 13:39 - 03 Mar 2004    Post subject: Reply with quote
No, not exacly the same.
The car oils usually have additives such as friction inhibitors which some people say will have an effect on the bikes clutch performance (but then some people also say the same about fully synthetic bike oils too). Doubt it would have a massive effect though and as Keith says, many people use car oil with no problems. Personally I still use bike oil for the bike and car oil for the car.
"Unlike public school you don't need to have your arse up and your head down to go a long way...."
PostPosted: 13:52 - 03 Mar 2004    Post subject: Reply with quote
Different car oils will have different additives. It was Texaco Havoline 10w40 which I used in the ZX6R and killed the clutch. Basically, I think it is just a case of finding out which is ok with wet clutches, and which isn't. Texaco Havoline isn't Wink
Mr C
PostPosted: 15:15 - 03 Mar 2004    Post subject: Reply with quote
so for the sake of saving a tenner every six months why not just buy some decent bike oil Rolling Eyes
187.3bhp = 201mph
PostPosted: 15:41 - 03 Mar 2004    Post subject: Reply with quote
I buy it in 20 litre drums. Semi synthetic costs around £45 like that. Buying bike oil would cost me probably £30 a 5 litre can, so around £120. Oil and filter change every 3 months or so on the commuter bike, plus all the other vehicles (oil shopping gets expensive when we tend to buy around 60 litres at a time), especially when the £75 difference in cost of buying that much oil is 10% of the value of the Divvy.
Yes the Bimota gets bike oil, but the mileage is also tiny. For the bikes doing a high mileage then I just use car oil, and not had a problem with it.
PostPosted: 15:46 - 03 Mar 2004    Post subject: Reply with quote
I do. Smile
I just bought car oil that once as it was low on oil and I thought it would be ok. Laughing
The last post was made 22 years, 86 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.97 - MySQL Queries: 13 - Page Size: 99.76 Kb
