| Carl Howell |
 Carl Howell Scooby Slapper
| Paddy Blake |
 Paddy Blake World Chat Champion
| Carl Howell |
| Carl Howell |
| Pete. |
 Pete. Super Spammer
 Posted: 15:42 - 21 Jun 2008 Post subject: |
Measure the link-pipe diameter then find a can that fits it.
BTW rather than cutting wires that might have to be re-joined just unplug the connector from the ECU and release that pin from the connector. Insulate the wire then it can be replaced at anytime. ____________________ a.k.a 'Geri'
| Carl Howell |
| Pete. |
 Pete. Super Spammer
 Posted: 16:35 - 21 Jun 2008 Post subject: |
That doesn't sound like something that will be cured by fitting a can. More of a fuelling issue. ____________________ a.k.a 'Geri'
| Carl Howell |
 Posted: 17:27 - 22 Jun 2008 Post subject: |
The main reason I want to change it is as the outlet hole should be (if it was standard) twice the size.
I think I've found an exhaust.
https://tyga-performance.com/site/product_info.php?products_id=1012
I think it will fit straight on and the I could weld the spring clips onto my original exhaust. It shouldn't stick out as its quite short. I think it will need setting up though as its nearly straight through and my bike revs up to 15000rpm so I don't want it running lean. If I put it on a dyno will they set it up there and then, or will they advise me on what setup to have.
One last question, can the exhaust be welded while on the bike or does it have to be taken off first? |
The last post was made 17 years, 192 days ago. Instead of replying here, would creating a new thread be more useful? |
