| 5v3d3b0 |
 5v3d3b0 World Chat Champion
| Ichy |
 Ichy World Chat Champion
| Ben. |
 Ben. World Chat Champion
 Posted: 21:34 - 17 Jun 2008 Post subject: |
top compression bottom oil/ lubricate the bore, middle is a bit of both... ____________________ follow my racing season
Race bike - R6
Road bike - sv650 |
| 5v3d3b0 |
| twotakt |
 twotakt World Chat Champion
 Posted: 22:29 - 17 Jun 2008 Post subject: |
Apparently with a single ring has less friction and as such they can rev easier. Higher revs=more power (to an extent), so the easier that these high revs are 'accessed' the more power is available.
But apparently the single ring is under more 'force' and exposed to wear and therefore need to be replaced more often than twin or triple ringed pistons.
This is what I've read and I'm not 100% sure these statements are fact.
Ta,
Jack ____________________ R.I.P. Tareree Shiimi, 1985-2008 |
| quacker_boy |
 quacker_boy Cuddle Bitch
 Posted: 22:57 - 17 Jun 2008 Post subject: |
Generally most four stroke engines will have three sets of piston rings, the top two rings are compression rings and the bottom ring is the oil control ring which prevents oil getting into the combustion chamber.
Most two stroke engines have got two rings for compression as the fuel and oil is mixed and the big end, small end etc are all lubricated by splash lubrication.
You only really need two compression rings as the rings have gaps to allow them to be taken on and off, the bottom one is just used to stop the motor loosing compression trough the gap in the top ring. So no, you don't really need any more.
Why'd you ask?
I'm yet to see an engine with more than three rings, although some of the older members might have seen them like Stink, Sickpup, Kickstart etc...
HTH  ____________________ wizzzard wrote: Imagine God just stopping by, tidying your front room up and then quietly letting himself out again. Statisticly more likely to happen than Korn being on here. |
| .Chris. |
 .Chris. World Chat Champion
| 5v3d3b0 |
| 5v3d3b0 |
| quacker_boy |
| 5v3d3b0 |
| Rockhopper |
 Rockhopper Trackday Trickster
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
The last post was made 18 years, 132 days ago. Instead of replying here, would creating a new thread be more useful? |
