Cigarette lighter on bike?
Pie-Roe
PostPosted: 10:04 - 20 Jun 2008    Post subject: Cigarette lighter on bike? Reply with quote
Can I fit a cigarette lighter to my bike? I have access to a variety of them from all sorts of car models, and I'm prepared to pay up to £30ish if I need to.
The bike I want to attatch it to is a fzr600 genesis '91.
I'm not sure if the battery is 6 or 12 volt, will have a look once dressed.
I assume, it could be simple enough to link it straight off the battery, BUT this would lose power quickly with the engine turned off no? So there would have to be some kind of ignition switch?
Cheers for any thoughts
Pyro
PostPosted: 10:47 - 20 Jun 2008    Post subject: Reply with quote
The battery will be 12V.
Red Mick
PostPosted: 10:57 - 20 Jun 2008    Post subject: Reply with quote
I've fitted these to several bikes, the last one I bought from the local motorist's discount shop for a couple of quid, complete with waterproof cap.
Siting the unit is sometimes awkward, top of fairing panel on some bikes, on the 'bird, I've made a little aluminium bracket fastened to the bar clamp bolt.
Wired in to the battery with an inline fuse, no battery drain when socket is not in use
I usually use these sockets for the sat nav,but it would also come in for 'phone charger or even compressor if you should carry one.
Itchy
PostPosted: 11:30 - 20 Jun 2008    Post subject: Reply with quote
HG do one for £12, if you want to make it work only when the engine is on , wire it up to the rear bulbs on a relay , but it shouldn't drain power if there is an incomplete circuit
I made my own for £2
Faraz
PostPosted: 14:46 - 20 Jun 2008    Post subject: Reply with quote
How do you smoke whilst riding without the inside of your helmet catching fire? Laughing
'56 Yamaha MT-01
'05 Nissan 350z Roadster GT
3 words dude.. Fvck. Yes.
map
Mr Calendar
PostPosted: 19:00 - 20 Jun 2008    Post subject: Reply with quote
I'm just waiting for the next post/thread of where to put the ash tray :winK: Laughing
On topic I have been told by some tourer types that the BMW style connector is better than a normal cig-lighter type. However, that causes problems because you can't plug the cig-type adaptors into it Rolling Eyes
If fitting I'd recommend making sure waterproof and water can't collect in it. Also fit so it's active only via a relay from a live feed and also fused (do a search on here for previous relay related items). However, disregard the active feed bit if it's absolutely essential to have on when the bike's turned off but then beware of flat batteries.
PostPosted: 20:25 - 20 Jun 2008    Post subject: Reply with quote
https://www.motrax.co.uk/images/products/300x300-JGTBK54_8.jpg
Smile
Phoenix
Twisted Firestarter
PostPosted: 01:57 - 21 Jun 2008    Post subject: Reply with quote
Just fitted one in the 'boot' of the Fireblade for my Europe trip to charge phone and MP3 player etc.
Got all the bits from Maplin, a socket with rubber cap cover with screw bezel to fit into the upright plastic panel of the undertray, a 30A 4 pole normally open relay, some 25amp wire and leftover thin guage wire for the relay trigger, oh and a 15amp fuse holder (won't be pulling more than 15amps as the socket is only rated to 15amps). The whole lost cost about £6 I think.
Best way to do it is just to wire it to a relay which is hooked up to a switched 12v (a wire that comes live with the ignition). I used one of the 12v feeds to the fusebox as they're easy to locate and you don't need to go testing anything to check whats live as the main circuits are all only live when ignition is on (except fan on some bikes).
The socket won't use power unless it's got something plugged into it because otherwise it's not a complete circuit, only the relay will draw a very small amount of power. The only reason to use a relay is it prevents you leaving something running off the socket while your bike is turned off, otherwise hardwiring to the battery would be fine, but always use a fuse.
deanoet
PostPosted: 12:27 - 21 Jun 2008    Post subject: Reply with quote
I bought One of these.
Sits nicely in my tank bag. Mainly used for sat nav, but as it is cig lighter can be used for anything with the right adaptors. Smile
Bardeey
PostPosted: 19:23 - 22 Jun 2008    Post subject: Reply with quote
https://www.ptreeusa.com/Peach%20Graphics/magnetic_parts_tray.jpg
Magnetic FTW.
lol.... Rolling Eyes
:: P Speedfight 49cc => Gilera DNA 124cc => Suzuki Bandit GSF V 400cc ::
:: CBT=Passed 07/08/05 :: Theory=Passed 31/05/07 :: Practical= Passed 02/08/07::
The last post was made 17 years, 301 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.75 - MySQL Queries: 13 - Page Size: 69.16 Kb
